Oil pressure gauge help
Does your 5.3 have an oil cooler delete plate?
https://ls1tech.com/forums/generatio...-write-up.html
Check out my build thread on my rusty 71 short bed. I have pics on how to make an adapter out of the stock sender. Works real good and allows you to use the original oil pressure line if you're keeping the factory gauges. https://ls1tech.com/forums/conversio...-c-10-a-2.html Post #26.
