Lt4 mounted in 69 camaro
Old 07-21-2017, 07:10 PM
  #61
Motown 454's Avatar
Originally Posted by Chandvogt
Yes I have it broke in. The motor has very good street manners but when given some foot all hell breaks loose! It's really exiting to drive and the screaming sound really turns heads around here.
I've been thinking about putting the oversized drive pully on it and getting a good tune for it.
In two weeks my dad and I will be going to the drag strip and will see what it can do. Should be interesting
We want to hear about how you make out!!
Old 07-25-2017, 03:04 AM
  #62
Jimbo1367's Avatar
More pics please, LOL
Old 07-27-2017, 09:06 PM
  #63
baconfat's Avatar
Thanks, did you add power steering?
Old 04-05-2018, 08:15 PM
  #64
whytry's Avatar
Still loving this setup? I’m looking at the Lt4 as 6 speed into my 68. Any chance you made a parts list?
Old 04-06-2018, 08:35 AM
  #65
Slow Z28's Avatar
In for that information too. I see the oil pan is out and ready, now I'm just hoping to see a first gen f-body engine mount setup that works with the hooker 4l80e trans x-member.
Old 04-06-2018, 09:44 AM
  #66
Toddoky's Avatar
I can say what you're looking for is something I've been working on in the Holley engineering lab, but I don't quite yet know when the parts will become available. The Hooker LT1/LT4 1st-gen engine brackets will work with all of the existing Hooker transmission crossmembers that were developed for the LS swap application.
Old 04-07-2018, 07:22 AM
  #67
Slow Z28's Avatar
Thanks Todd,
I had bought all the LS stuff to do an LSA/4l80e swap but the LT4 crate engine is intriguing.
But i'd have to have the DSE front subframe since those mounts are available, the stock subframe mounts aren't out yet, correct?
Old 04-07-2018, 08:42 AM
  #68
Toddoky's Avatar
Thanks Todd,
That's correct, the mounts for the DSE subframe have been released but the mounts shown in the photos I posted for the stock subframe have not.
Old 04-07-2018, 12:59 PM
  #69
Project GatTagO's Avatar
Received 1,386 Likes on 875 Posts
A-bodies next ?
Andrew
Old 04-07-2018, 02:21 PM
  #70
Toddoky's Avatar
A-bodies next ?
Andrew
I've not been informed of what's on the horizon in that regard Andrew. I've personally been developing various Fox Body swap systems exclusively for the past 1.5 years and look forward to moving on to a new platform in the near future.
Old 04-23-2018, 07:02 AM
  #71
Slow Z28's Avatar
Any updates I know I'm wishful thinking but since Summit has been complete idiots regarding my 302-3 pan order from a month+ ago that was supposed to ship on 4/4 and still hasn't, I'm at the point of just returning all the LS stuff and just wait for the LT stuff and order though a MUCH better company. No more walmart of the performance industry for me.
Old 04-23-2018, 11:22 AM
  #72
Jimbo1367's Avatar
Check out Jegs
Old 04-23-2018, 11:25 AM
  #73
Jimbo1367's Avatar
Toddoky,
The LT1 headers look good. It doesn't have that one primary that goes over (Cyl 3 over 5&7)
Old 04-23-2018, 11:53 AM
  #74
Toddoky's Avatar
Toddoky,
Correct Jimbo1367, they follow the same tube routing scheme as the Hooker Blackheart LS swap headers.
Old 11-27-2018, 05:37 PM
  #75
whytry's Avatar
still hoping there is a swap kit for 1st gen's ready...
Old 11-27-2018, 06:00 PM
  #76
For a stock subframe, Holley has the mounts ready and oil pan available. You just purchase the LS swap frame stands and then get the LT engine mounts that are designed to work with the LS frame stands. They have taken into account the geometry differences between the LS and LT...
Andrew
Old 11-28-2018, 06:31 AM
  #77
Toddoky's Avatar
Andrew is partially correct. The engine mounting in this application is based around the use of the original GM clamshell mounts in the Hooker Blackheart LS and LT swap systems and requires specific engine-side brackets for each. We are working through the first production run of the LT swap headers now and the engine mounting brackets should become available in January. The Holley LT swap pan is available now and fits the application perfectly.
Quick Reply: Lt4 mounted in 69 camaro
