thermostat and electric fans
Old 03-09-2016, 05:31 PM
Houston_t's Avatar
Default thermostat and electric fans
Need to tell the tuner what temp to have my fans turn on running dual fans and was wondering what temp thermostat I should run. I stay in MI and this will be a stock 5.3 daily driver with no mods other than dual exhaust and maybe a cold air kit
Old 03-09-2016, 05:42 PM
Pop N Wood's Avatar
I run a 160 degree thermostat. GM uses the hotter ones for emissions reasons. I've been told these engines produce more power the cooler they run.
Old 03-09-2016, 05:44 PM
Houston_t's Avatar
Yea not worried about emissions here in MI. If I go with a 160 thermostat what would be good temps to have the first and second fans kick on and off ?
Old 03-09-2016, 06:43 PM
DW SD's Avatar
If 160F on thermostat..... I would set off @165F to 170F and on @ 175F to 180F. If you set off as too close to 160F, it will never turn off. Maybe on @ 180F and off @ 170F to make sure the fan cycles.
When you are moving, if your radiator gets flow and is in good shape, you should stick your temps @ 160F.
Doug
Old 03-09-2016, 06:47 PM
Project GatTagO's Avatar
Received 1,384 Likes on 873 Posts
If you have a CAI there is no reason not to run a stock thermostat (187 degrees), especially if the car is going to be a daily driver. With a stock thermostat leave the oem fans parameters alone.
Andrew
Old 03-09-2016, 06:58 PM
Houston_t's Avatar
Is there a benefit to running the stock temp thermostat
Old 03-09-2016, 07:00 PM
More efficiency and more heat if you're driving in MI winters.
Andrew
Old 03-09-2016, 07:01 PM
Houston_t's Avatar
Cool. Thanks
Old 03-09-2016, 07:05 PM
Cool. Thanks
Hot actually
Andrew
Old 03-09-2016, 07:07 PM
Houston_t's Avatar
I see what you did there.
Quick Reply: thermostat and electric fans
