90 Camaro LS-1 Swap Issue
Just finished up an LS-1 swap for my 90 Camaro convertible. Motor and computer came out of an 03 Corvette (wiring harness for swap done by Hawks 3rd Gen). Bolted up a brand new GM 4L65 transmission to it.
ISSUE: Speedometer and Mileage do not work in the gauge cluster, and oil pressure gauge is pegged high (Battery, Fuel, Temp gauges all work fine).
Went through the wiring and confirmed that oil pressure sensor and transmission speed sensor are both plugged in correctly with no loose connections. Currently do not have the cruise control module in the car (plugged it in and ran car to see if that would solve the issue, no luck) and that does not seem to be the problem. Had the gauges out at one point to replace all the lighting, have made sure all connections are back in place and tight.
Looking for ideas what else I can check if anyone else has had the same issue.
Thanks
Thanks
