4L70E Trans Cooler Line Fittings
Don't have much room for the fittings.......Need 90 Deg fittings........Anyone already been there to help solve this problem......They are 9/16 thread "O" ring style...........
Thanks in advance
Ken
Thanks in advance
Ken
they make banjo fittings with an -6AN male end on them.
http://www.ebay.com/itm/6AN-transmis...1UvYUn&vxp=mtr
cant imagine they flow very well though.
I have used the regular 9/16 oring to male AN and then the 90* hose end and it works well. projects about 2" off the case.
Do you have room for one of these?
http://www.jegs.com/i/Earls/361/9211...rentProductId=
You will have to use the o-ring fitting, then adapt from there, just put a 70E in, same package as you are doing now....
T,
T,
I really like those tranny banjo fittings. I wonder if that flow suffecently though
I bought a set of those but the thread size is incorrect.......can't use them....They would have worked perfectly if the threads were correct.......Darn !!!...........I'm trying to find the 9/16 threaded ones you are talking about.....
T,
T,
That's exactly what I needed,...........I couldn't find them.....LOL
Thanks Tom............
Ken
Ken - For the life of me, I can't remember where I read it, but I think I read somewhere that banjo didn't flow enough and even transmission experts don't suggest doing a 90* I am planning on using these, but expect to have to clearance the floor to make some room. http://smile.amazon.com/Russell-6604...ilpage_o05_s00
No worries, I found out the hard way.
Those won't work on your 70E. You need the o-ring style, the thread pitch is also different....
T,
T,
Argh. Thanks Tom. Do you have a part number? Russell, Fragola, TCI...don't really care. Just want to make sure I get the right ones. I'm planning on ordering the Connect and Cruise set up from GMPP, so I assume it won't be an older 4l70e
