LM7 to LS6 intake anything new?
Old 05-31-2016, 12:06 PM
442scotty's Avatar
Default LM7 to LS6 intake anything new?
I have been trying to see what new in doing this swap. Bits and pieces in posts... some of them quite old.. my old head is starting to hurt lol...
I have the 5.3 truck LM7 from a 2002 GMC and am putting it in my 65 Cutlass.
I have access to a complete LS6 Manifold with injectors, TB etc. The only thing that seems to come up for sure is that my truck water pump wont work. Is there another water pump that will work that doesn't require changing anything else in the way of accessory mounting?
Has someone documented a list of things that needs to be done recently with links? complete swap system from someone?
Thanks
Old 05-31-2016, 02:12 PM
Restricted User
JoeNova's Avatar
Car intake, car water pump with spacers, pulley relocation bracket.
Old 05-31-2016, 02:19 PM
rennat_2006's Avatar
07 and newer truck water pump or 5th gen camaro water pump. Truck one being the cheaper
Old 05-31-2016, 02:47 PM
442scotty's Avatar
I will try the truck water pump! if that's it plus maybe some pulley relocation
Old 05-31-2016, 02:56 PM
Steven32's Avatar
I have a 6.0 with the ls6 intake. Used the stock truck alternator bracket (Had to cut a piece off to clear the throttle body), ls3 water pump with 1.5" spacer, and pulley relocation.
Old 05-31-2016, 04:37 PM
442scotty's Avatar
Thanks all
Old 06-01-2016, 12:20 PM
hookemdevils22's Avatar
Camaro L99 (later LS3s are also the same) water pump has outlet on the driver's side, while the L92 truck (ex 2008 Cadillac Escalade 6.2L) has it on the passenger's side. You'll need the tensioner from whichever you choose, too, as the mounting points differ. I have a write-up near the end of my build.
Old 06-01-2016, 12:43 PM
07 and up truck pump is like $160 vs over $300 for 5th gen camaro pump when i was setting up this chevelle.
Old 06-01-2016, 10:03 PM
442scotty's Avatar
thanks!
Old 06-02-2016, 09:57 AM
alowerlevel's Avatar
https://ls1tech.com/forums/new-ls1-o...cessories.html
Old 06-02-2016, 11:32 PM
442scotty's Avatar
Awesome!!
Quick Reply: LM7 to LS6 intake anything new?
