Ls1 swap extra pieces help
Old 06-02-2016, 07:21 AM
Camaro70ls2's Avatar
Default Ls1 swap extra pieces help
Hello everyone
Just did BRP ls1 swap on my 70 camaro there are few bolts and one small aluminium block piece left I don't know where that goes please if anyone can help me with this.
It was in the package of engine mounts and transmission mount kit.
Old 06-02-2016, 07:29 AM
Restricted User
JoeNova's Avatar
Looks like a trans mount spacer.
Old 06-02-2016, 07:46 AM
For the spacer do you think they should give long bolt?how will I know if I need to install the spacer?
Old 06-02-2016, 11:46 AM
jayyk31's Avatar
The spacer is used to dial in your driveline angle of the transmission. You should measure the current angle and determine if u need the spacer/how thick of a spacer/ or if u don't need any spacer.
Old 06-02-2016, 06:07 PM
Thanks alot I will check it.
Quick Reply: Ls1 swap extra pieces help
