Cruise control wiring for DBW, what type of switches
So the instructions I got from the wiring harness company I used say to used NORMALLY CLOSED momentary switches for the "cruise set/coast" and "cruise resume/accelerate".
All the diagrams I look at looks like you should use NORMALLY OPEN momentary switches.. Just want to see which is correct..
Does PCM look for a pulsed 12v signal? Or as a normally closed switch would provide- a constant 12v source and when pushed it cuts the 12volts momentarily
Thanks
Thanks
A normally closed switch is generally opposite to the way cruise the control Circuits I have used operate.
A little more information would be helpful. Who's wire harness are you using and what PCM, is the cruise controlled by the engine PCM or an outside module?
http://chevythunder.com/drive_by_wir...C%20Controller
On switch is toggle, set, resume are momentary.
I guess I'll just wire it up using normally open momentary switches and hope to god nothing bad happens when I flip the 'on' switch... lol
Right, but I was questioning the initial position of the momentary switches. Instructions say to use 'normally closed' when everything else says to use 'normally open'
Anyone know what else I can check?
