67 firebird LS1 Boggs at starting line
My 67 Firebird is starting to bog down from a stop. Also at the beginning of every gear during exceleration. I have checked for:
A Vacuum leak,
plugs and wiring
Intake manifold seating
For my ignition I'm using the MSD Atomic system. On it's handheld device it shows no errors in the system.
HELP I want to spin my tires again!
A Vacuum leak,
plugs and wiring
Ok I'm going to assume fuel pressure has been measured at the rail & is good. That to me screams vacuum leak. If the computer is not detecting a misfire then its your fuel or vacuum. I would smoke the engine and/or leak-down test the cylinders. Good luck I want you to do burn outs too
Smoke test done, fuel pressure 57psi. It's also overheating a bit at 212F (water boiling point) but that may stand to reason since the ambient temperatures here are about 105° But I would like your opinion on the temperature. And yes the thermostat was checked, opened at 185 and both fans on. Could you please explain how to do a leak test the cylinders?
Fuel rail system
My Badassbird!
Fuel rail system
My Badassbird!
