Turbo C3 76 Corvette, 4l80E, 4 link rear, street cruiser/strip fighter - Page 4 - LS1TECH - Camaro and Firebird Forum Discussion
Go Back  LS1TECH - Camaro and Firebird Forum Discussion > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Conversions & Hybrids
Reload this Page >
Notices
Conversions & Hybrids LSX Engines in Non-LSX Vehicles
Old 12-20-2018, 03:19 PM
  #61
LSswap's Avatar
Did I mention the pump cost me $30 at the pick and pull and included the connectors and shock mounts? When I told the guy it was for a project, he cut me a deal.
LSswap is offline
Old 12-21-2018, 10:58 AM
  #62
LSswap's Avatar
I just swapped the regulator in my alternator from 4 pin to 2 pin, so now it's like a 2006 or newer alternator.
I PWM it directly from my DIY transmission/car controller. I can command the alternator not to do any work till a few seconds after the car started and then slowly ramp up the voltage to normal levels. I may also measure the battery voltage before the engine starts and increase the charge for a while if it was low.
I started a thread in Hybrids section, on how to use the 2 wire 2006 and later alternator without a ECM/BCM. 2 pin 2006 + alternator. Don't throw it away!!
LSswap is offline
Old 12-21-2018, 07:58 PM
  #63
Love this build! You sir are a genius!
Che70velle is offline
Old 12-21-2018, 10:19 PM
  #64
gofastwclass's Avatar
I love your creativity.
gofastwclass is online now
Old 12-22-2018, 09:04 AM
  #65
LSswap's Avatar
tell that to my ex .
I like the quote at the end of your sig.
LSswap is offline
Old 12-24-2018, 02:20 AM
  #66
Which year Volvo C70 for the electric power steering pump? Any other Volvo models use this? Id rrally like to try this on my setup. Thx
80/TA/LT1 is online now
Old 12-24-2018, 08:23 AM
  #67
LSswap's Avatar
I pulled the pump out a a S40. But my buddy who works for Volvo said the pumps from all the models that use them work the same. There may be one that has a variation on the reservoir, with a remote extension.
LSswap is offline
Old 12-24-2018, 10:09 AM
  #68
Is the EX the one who liked C3's and went to the Caribbean with you?
Jay
JayinMI is offline
Old 12-24-2018, 02:35 PM
  #69
LSswap's Avatar
Jay
lol no, shes a keeper
LSswap is offline
Old 12-28-2018, 12:21 AM
  #70
LSswap's Avatar
Bought a "Maxi" fuse holder and 80 amp fuse for the power steering pump.
The white fuse is the 80 amp maxi, blue ones are standard mini and micro fuses just for size.
I'm impressed by the 8 GA wire on the fuseholder.
LSswap is offline
Old 12-28-2018, 06:09 AM
  #71
Project GatTagO's Avatar
Burried in my Cougar build thread is my experience with those. Never again.
Andrew
Project GatTagO is offline
Old 12-28-2018, 02:28 PM
  #72
LSswap's Avatar
Andrew, Thanks for the heads up. I'll go and check it out.
LSswap is offline
Old 12-28-2018, 08:20 PM
  #73
LSswap's Avatar
Over the past 2 years, I've completely redesigned the DIY 4L80E controller and body module.
The first version was based on an Arduino Due processor board and LCD display. The reason I used the Due was because it was blazing fast. But it had some down sides as well. These down sides included inconsistent power up, 3.3v instead of 5 volt operation and no built in NVRAM (can't store settings when powered off). I worked around these and got it to work, but I wasn't happy with it and the display sucked.
The new (final) version is based on the Arduino Mega board. As it turns out, the Mega is more than plenty fast enough for the task. It's a 5 volt board, so no jumping through hoops to interface it. It can store and retrieve settings after being powered off. Has lots of I/O pins to connect to the rest of the world.
Here is some of the basic functionality:
It controls the 4l80E
PWMs all the fans: 2 radiator, 2 intercooler, trans cooler and oil cooler
PWMs the two fuel pumps
PWMs the alternator
Connects to the AEM infinity with CANBUS
Controls Boost
Controls the BOV
Displays alarms from AEM or itself.
Triggers the AEM two step
Controls the backup lights
Controls the brake lights
Scramble button
Fuel level sensor
Paddle shifting input
Line pressure input
4L80E temperature input
7" touch screen display and control center
I don't plan on having any gauges in the Vette. The touch screen has more than I need to use this car as both a cruiser and strip car.
This is the heart of the controller
LSswap is offline
Old 12-28-2018, 08:26 PM
  #74
LSswap's Avatar
LSswap is offline
Old 12-28-2018, 08:41 PM
  #75
As a former Neon owner (2 97 ACR coupes, and a 98 R/T coupe) and occasional Arduino hobbyist, you have my attention. lol
JayinMI is offline
Old 12-28-2018, 08:49 PM
  #76
LSswap's Avatar
This is the display/control with the 6.0 running. This is not the final enclosure, just something I 3D printed.
The Vette can be operated in a bunch of different modes. Each mode has it's own shift logic, shift points, boost in each gear and display screens.
This is cruise mode. Automatic upshifting and downshifting is based on load and MPH or optional paddle shift. Cruise mode and be switched to sport mode which is like cruise mode, but with higher shift points and more boost per gear.
LSswap is offline
Old 12-28-2018, 08:59 PM
  #77
rkupon1's Avatar
Awesome, this stuff truly amazes me. I pray the fbi never raids your basement, with everything you ve got goin on, you may some splainin to do,lol...jk, great work
rkupon1 is offline
Old 12-28-2018, 09:28 PM
  #78
LSswap's Avatar
Thanks... Did you notice that my Neon was a 2.2 liter? 425 at the wheels at 21PSI through a loose automatic. I ran at 34PSI.
Ryan, not worried... they'll get a headache trying to figure it all out.
LSswap is offline
Old 12-28-2018, 09:41 PM
  #79
LSswap's Avatar
Here's burnout mode.
Each mode has many nuances and rules. For example burnout mode can be locked out if the shifter is not in 3. shifting is triggered by RPM only. It only shifts from first to second and has it's own set of boost levels for each gear. When the MPH comes back down at the end of the burnout, it automatically changes to drag mode.
LSswap is offline
Old 12-29-2018, 02:28 AM
  #80
Yeah, I saw that. I seem to remember someone building a Shadow/Sundance with a 2.4L bottom end and 2.5L head some time ago.
I dug a lot of the Chrysler turbo stuff back in the day. I always thought it would be fun to take an AWD, woodgrain sided Chrysler Minivan and add a 2.2 Turbo/5 speed combo and go **** off Mustangs.
A friend of mine back then had a pretty fast 97 ACR Coupe that became a race only car. Ever heard of Matt Tripp?
Jay
JayinMI is offline
Quick Reply: Turbo C3 76 Corvette, 4l80E, 4 link rear, street cruiser/strip fighter
About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
