Turbo C3 76 Corvette, 4l80E, 4 link rear, street cruiser/strip fighter
#101
I would think that you're probably closer to having it work right with a 4l60E shifter, but that's just a guess.
#103
If I remember properly the 4L60E and 4L80E used the same throw shifter arm on the transmission but I could be incorrect on that. I just find one in the salvage yard, measure the distance and make what I need if the stock one won't fit.
#104
The fan connector only has a few strands of wire left in the ferrule and the plastic shield slid back exposing the power to the chassis. Obviously the guy who did this did not have the right tools. Did I mention I'm not a fan of mechanical butt splices.
#105
That's true. Right to the point where their car has intermittent electrical issues or burns to the ground due to a wiring fault. Oh the stories we could probably share.
Jay
#106
My son just brought a project car, that he just bought, to my garage. Here is a picture of the fan connector.
Jay
#107
I finished wiring up most of the new fusebox yesterday and fired it up. Started right up but had some engine surging. Couldn't keep it on long, because my garage CO2 sensor wasn't happy.
Have to put in brake fluid and bleed entire system, put the steering wheel back on the column, re-calibrate the computer to the throttle pedal, transfer the latest code to the transmission controller/body module, drop it off the jack stands and the car will hopefully move on it's own for the first time in 20 years.
#108
CO2 sensor or CO sensor? CO will kill by poisoning, but CO2 only by displacement
#110
Brake fluid is in. Leaks fixed. Brakes bled.
Now for the exhaust. Only the passenger side will get an exhaust since it's a single turbo car.
I already had a 3.5" stainless downpipe completed earlier, with a V band flange at the end. For the external part, I decided to go with a 4" aluminum because 4" gives me options for inserts if I find that it's too loud. My Plymouth Neon exhaust was 4" aluminum and was no longer being used, so I reused some of the tubing and all I needed was one 180 degree bend to complete the vette exhaust.
Also 4" give me options for heat shields. I went with a 46" Patriot heat shield. Very reasonable.
I was planning on painting the aluminum part black, but now I'm not sure. My buddy had all black side pipes and I kinda liked them. Opinions welcome.
I was short about 2" of straight tube, but it will do for now. I can always add in a little more if it bugs me.
If it's too loud, I might add a V band flange, right where the straight part starts so I can pop inserts in and out or just easily swap in a quieter exhaust for those long cruises with my honey.
The following users liked this post:
V8 Cowboy (05-28-2023)
#113
Got a pair of Jegs 15x8 4.5" setback JEGS Sport Star wheels for the front to match the back ones. They don't make a 4" setback and the 4.5" ones rubs against the brake caliper. So I machined a pair of spacers I had laying around to a .300 spacer and hubcentric.
#117
I'm back off to the garage to figure out one of my re-wiring bugs. Completely forgot about the flashers switch and wired them to be on all the time. Two steps forward and one back.
#118
4 link
Hello could you share the link of the 4 link kit you bought and then modified. Also if you have a picture of how you modified the frame side. I'm about to do this on a 78 twin turbo vette. Plan on using an explorer rear end with out shortening the one side and hope the offset is not too bad. Any more pics or comments on doing the 4 link would be very helpful.
#119
Here are some of the parts I used.
http://www.appliedracing.com/4-link-...ame-rails.html
http://www.appliedracing.com/art---jbrc-4-link-housing-bracket---1-4-ms-5-8-holes.html
I liked these because they had 5/8 holes and the fine adjustment capabilities.
The web links for the each of the 4 link tube and end parts don't work anymore, but I used https://www.qscomponents.com/
I think you may end up having to shorten both sides of the axle. There's not much wiggle room to locate the pumpkin because the driveshaft tunnel is narrow. If you're in NJ, you can borrow the 8.8 narrowing jig.
Also I had to cut open the body, above the pumpkin to add room for the pumpkin to move up and down.
Hope these help. I can take pics of any specific parts you might be interested in.
#120
Here are some more pictures of the 4 link and rear.
I reinforced the frame by welding an elbow to the 4 link bracket.
I was able to fit 1350 joints without modifying the tunnel.
