Cruise control switch for dbw swap
So I have been looking for a switch for cruise control on my chevelle swap. I have searched to see what others have used. I saw some have used the digital Dakota switch but you have to add relays. I was wondering if anyone had tried the rostra precision controls switch? https://m.summitracing.com/parts/rpc-250-3020
Also open to other ideas.
What about modifying a switch from 80s Chevy Truck with the wiper and cruise control switch on the turn signal.
I read about someone using the turn signal switch from late 80s early 90s camaro. I can't find the thread anywhere.
I was just reading your write up on 67-72chevytrucks.com I'm going to check my local junk yard tonight.
Could you buy the digital Dakota switch or the rostra switch and change the inside of the switch. The same way you have to change the inside of the 81-84 truck to the 4 wire switch?
These are the 2 switches I found
This is the pig tail that was in the 95 suburban it's different than the gen 4 camaro but I think it still should work.
Let me know what you think also going to try to maybe repaint the letters on the lever so you can see them.
Looks like you're on the right track, those are the pieces you need. You did good by finding two of them, I cant seem to find them around here any more, I guess I've cleaned the yards of them! Anyway, since you saw the write up you know how I do them, but the only thing I do differently now is find a long single q ire and resolder them directly to the switch, it makes for a cleaner job.
As for painting the lettering, I never had any luck with it so I had these stickers made. You need to paint the black part so that its dark and better matches, but it makes them look really nice. If you want one I can sell you one for 3 bucks shipped.
The following users liked this post:
CAM78 (03-25-2020)
I wired the pigtailed the way you said and got everything all wired up today. I'm guessing the switch is bad because the cruise doesn't work. I'm hoping to get some time to troubleshoot it tomorrow.
I tested with test light to make sure there is power with all the switch functions. So I'm thinking it's not the switch it's something else. I used the 3 wires that psiconversions left for the cruise.
Yes I have regular filament bulbs, also I have the tcc brake switch from psiconversions. Its wired the way psi says to wire it. So I'm not sure I'm going to call psi tomorrow.
I have the wires hooked up and wired correctly I think. I called psi they said its probably not working because I have a P0706 code about the PRNDL switch. Which is something that they were supposed to flash out before they sent me the pcm. So I'll see if getting that removed if it fixes the cruise.
