LQ4/4L80 swap 1969 Mercedes
Old 10-03-2016, 01:38 AM
Coasttocoast's Avatar
Default LQ4/4L80 swap 1969 Mercedes
In January I purchased a stock, clean, original 35k mile W114 (Mercedes nomenclature) out of Washington state and had it shipped to me here in Honolulu. I've wanted to build a sleeper for a year or so and planned on a newer Mercedes engine. But after I purchased the engine I planned to build up I couldn't get around the fact that 280 HP would be the limit without a turbo. And that's after spending a good amount of money and time.
I swapped a 4.8 Vortec into my YJ 5 years ago and it makes me smile every time I drive it! So midstream I changed my mind to swap a "sure thing".
Mercedes has used this chassis for their 6.3 V-8 and others have swapped in other V-8's so I knew with a little work it could be done. This is a unibody car and is pretty light, front 1760 rear 1400 total 3140 lbs as stock, 1/2 tank of gas with its inline 6 and auto trans. Perfect for a little upgrade.
While driving it around somewhat as a daily driver until June when I put in on jack stands in my garage, I made a list of items to change/upgrade.
At this point I have purchased a 2005 LQ4/4L80 dropout, fit it to the car, purchased the items for the rebuild and the trans is at one shop getting refreshed and the engine components are at the machine shop.
Here is the car just before starting;
LQ4/4L80 swap 1969 Mercedes-image.jpeg
Old 10-03-2016, 02:20 AM
No real goals for power, this will be somewhat my daily driver. We have a lot of traffic here in Honolulu and no track. So this is more for fun than trying to hit specific numbers.
My block has already been cleaned, hot tanked, magnafluxed, blasted and measured. Due to a little pitting going to bore 30 over. It had spun a rod bearing and so I purchased a rebuilt crank. New flat-top pistons from Autotec, I beam rods from Scat, and a Pat G spec cam from Texas Speed 218/224, .600/.600, 114LSA +4. Now that all the parts have arrived and at the machine shop the rotating assembly can be balanced and the block honed to fit the pistons.
Along with new bearings, LS3 head gaskets, Melling 10295 oil pump, new chain, and all ARP bolts have been purchased.
The stock 317 heads are getting a valve job, PAC 1218 springs fit to spec and milled .030 to help raise compression. Yesterday the rockers arrived back from Harland Sharp from getting their trunion upgrade. Morel 5315 Lifters
The engine bay is tight so I purchased a set of Hooker Headers coated cast iron exhaust manifolds. They say there good to 500HP so shouldn't be too restrictive. But they fit is the real plus.
Induction is LS3 throttle body, Speedmaster intake, Holley fuel rails, Fast 36 lb injectors (42 lbs @58 psi).
I also purchased all new engine sensors, water pump and coil packs.
150 Tunes rebuilt the wire harness and preprogrammed the ECU to match everything I bought including matching the harness to the injectors, split to fun down each side of the intake LS style, longer lead to the mass air flow and enough length to mount the ECU under the dash.
Dirty Dingo is my source for front drive brackets and A/C compressor. Look great and fit to the engine/chassis like a glove.
Here is a pic at the fitment stage;
LQ4/4L80 swap 1969 Mercedes-image.jpg
Old 10-03-2016, 02:35 AM
The engine bay took a little work to fit the engine. I built a new firewall, one to replace some rust spots and two to push the engine a little more rearward for balance.
The transmission tunnel took a lot of work. The 4L80 is about 2" wider and longer. I had to widen the tunnel by 1" on each side and weld in addition support side to side and up and over the tunnel to support the added weight of the trans. My placement of the engine put the tail of the trans back about 8" from the stock location. I purchased Lokar's tail mount shifter and that actually placed the shifter right at the stock location.
I had to modify the crossmember to fit the engine with a front sump pan, and add some metal for additional strength. The new motor mounts are almost exactly in the same location as the stock ones.
After I mocked everything up to the engine and trans I pulled them and sent them off while I finished the tunnel, engine bay, crossmember, motor mounts, steering and painting.
Here is where I started;
And here is where I finished yesterday;
Old 10-03-2016, 10:37 AM
Jimbo1367's Avatar
This should be a cool car and surprise ALOT of people
Old 10-04-2016, 09:17 PM
Project GatTagO's Avatar
Received 1,386 Likes on 875 Posts
Looking forward to updates!
Andrew
Old 10-05-2016, 01:16 AM
Jimbo, thanks for commenting. I'm hoping it's going to be as cool as the image in my head. For sure will be fun to drive.
Old 10-05-2016, 01:32 AM
Andrew
Andrew I will update as I move forward. I'm hoping to have it drivable by Thanksgiving. As I mentioned above I have already fit the engine and trans to the car. I brake booster was installed, front drive assembly all the way to the intake tube and air filter.
Motor mounts are installed but the transmission mount still needs to be finalized. I have already purchased all the parts to connect the 4L80 to the stock MB diff, just need the trans installed to get the final length and take the parts to the local drive shaft shop. I forgot to measure the length before I pulled it the first time.
The MB used a steering gear box the size of a mini fridge, no way to route the exhaust around it. So I'm changing to rack and pinion. I have already fit a 1992 Cavalier unit, but need to adjust final brackets after the exhaust is complete. Very tight fit. Should be a small upside to the R&P but the downside is loss of some of the turning radius.
I have also dropped the fuel tank, cleaned it up, and installed an in tank fuel pump.
After its drivable it will get final tuned on the dyno.
Old 10-05-2016, 09:58 AM
slocaddy's Avatar
Bad *** build! Can't wait for burn outs!!
Old 10-06-2016, 12:09 AM
Cool Caddy! We used to live in Sarasota, loved our time there.
I can't wait either! Hope the engine gets out of the machine shop next week.
Stay tuned.
Old 10-06-2016, 01:17 AM
slocaddy's Avatar
Small world, I'm also shooting for same deadline as you, good luck
Old 10-06-2016, 12:03 PM
What sort of rear axle and suspension do these cars have? Will it live?
Andrew
Old 10-08-2016, 06:41 PM
vannatta20's Avatar
I wanted to swap a ls in a w124 but Mercedes makes it so hard. The steering system is the biggest problem. There is just not that much room in the engine bay. Also the trans tunnel is very small
Old 10-09-2016, 11:39 AM
Your build really will be "sinister"! Good luck to you as well. One of these days I want to build and all out turbo version. Are you fitting larger rear tires to get that power to the ground?
Old 10-09-2016, 11:48 AM
Andrew
For right now I'm keeping the stock IRS. Not a lot of info available on how much power it can take. So I'm shooting for a "safe" 450 crank HP. My weak link should be the tires, I can only fit 225mm (8.9") tires.
Old 10-09-2016, 12:03 PM
Yes, exactly my problems/challenges! Before I sent the engine and trans out for rebuilds I fit the assembly to the car. With careful parts selection and a couple of moves front to back I was able to make it work. I took this process seriously as I planned to completely shave the firewall and inner fenders. I completed the install to the point of installing the K&N filter and making sure I could still change the spark plugs. Good thing too. I thought my front to back location was good, but could not route the intake tube between the alternator and radiator/shroud, so ended up moving it back almost 2" more.
After a couple of evening this week my engine bay is ready
LQ4/4L80 swap 1969 Mercedes-img_1457.jpg
Old 10-09-2016, 12:34 PM
I'm using the stock 317 heads, milled 0.030 with springs to match my cam. Even though I don't need the power I plan on cleaning up the heads a little. So to practice I bought some tools and started work on the intake.
I bought the cheaper Makita grinder without the speed control and purchased a $25 fan control from a local garden center to control the speed, works good. Then some burrs from Buckeye Carbide, sanding rolls and cross buffs from Summit.
LQ4/4L80 swap 1969 Mercedes-img_1458.jpg
You can see in the pic the ridge around the beginning of each runner. This ridge is protruding out from the wall as much as 3/16". With the burr I shaved it flush all around.
LQ4/4L80 swap 1969 Mercedes-img_1459.jpg
In the last pic I have finished with the burr and working on the sanding, paying special attention to the short turn radius. As I understand it, when porting the head you only sand to 60 grit to keep the fuel from puddling, but the intake runner is pre fuel so I plan to take to 120.
LQ4/4L80 swap 1969 Mercedes-img_1460.jpg
There are some casting lines in the runner that I will flatten and maybe a little port matching, but no plans to otherwise enlarge the runners.
My first time trying this, kind of fun, and harder than it looks, more fun this coming week!
Old 10-09-2016, 02:09 PM
truckdoug's Avatar
a little tip i learned back when i was a puppo---die grinding on camel hump sbc heads---was to use a piece of stiff cardboard as a template for matching throat widths and cross sections. make different templates for different depths into the throat.
looks like a fun project, nice work on that engine bay!
Old 10-09-2016, 09:58 PM
slocaddy's Avatar
For now I'll just be putting the fattest tires I can stuff under the skirts, still just the stock open diff, so next year I'll workout a plan for a mini tub/posi/airbags then we will see about getting it to the ground lol
Old 10-11-2016, 01:26 AM
Thanks for the positive comments and the suggestions. I've also seen coat hangers bent up as a guage too. I'm a big fan of templates, makes a lot of projects repeatable and easier.
Old 10-11-2016, 01:29 AM
Major work there! Will be "wicked" fun!
Quick Reply: LQ4/4L80 swap 1969 Mercedes
