New Hooker Fox Body Mustang LS Swap System Preview Thread
Old 07-14-2017, 10:47 AM
  #201
79LS1FOX's Avatar
Any idea on when the mount brackets and headers will hit the market?
Old 07-14-2017, 12:06 PM
  #202
Toddoky's Avatar
The first limited batch of headers will hit first within the next week or two, my guess on the engine brackets 45-60 days.
Old 07-14-2017, 12:46 PM
  #203
jaywill's Avatar
will u all be selling tha turbo flange w/piping to hook to manifolds ?
Old 07-14-2017, 06:30 PM
  #204
Toddoky's Avatar
There are 5 different transmission-specific crossover tubes available now that connect the manifolds together on the back side of the engine. I did prototype a bracket to mount the turbo to the engine, and also a flanged pipe to connect the turbo to the passenger side manifold outlet...both of those will eventually get released as products as well, but I don't know when.
Old 07-15-2017, 11:36 PM
  #205
jaywill's Avatar
thanks a lot 4 the info..i have put manifolds and crossover in my wishlist on summit lol
Old 07-16-2017, 12:16 PM
  #206
In-Zane Moderator
ZONES89RS's Avatar
Was a hooker header available for the fox?
Old 07-17-2017, 06:26 AM
  #207
Toddoky's Avatar
Yes there is and the first small production run of the 1-7/8" version of them is nearing completion now.
Old 07-17-2017, 09:33 AM
  #208
In-Zane Moderator
ZONES89RS's Avatar
Good to know.
Old 07-17-2017, 08:31 PM
  #209
68roadrunner's Avatar
Will the crossover pipe fit an ls1 fbody oil pan in a fox with an 80e?
Any photos of the passenger side turbo placement ?
Old 07-17-2017, 09:11 PM
  #210
Toddoky's Avatar
I don't do mock-ups with any oil pans other those offered by Holley or Weiand, so I can't conclusively answer your question regarding the F-body pan.The 4L80 fits great using the Hooker engine brackets and transmission crossmember. The turbo was configured to be mounted on the driver side in our mock-up to permit mounting it to the engine and also to allow A/C operability.
Old 07-23-2017, 01:43 PM
  #211
BROWNEYE2.0's Avatar
I am watching this intently. I'm literally biting my nails for these headers. #KOOKSAREKOOKOO$
Old 07-28-2017, 05:12 PM
  #212
Toddoky's Avatar
I'm glad to have you on board with the thread and interested in the headers BROWNEYE2.0. If you are wanting to use them with engine mounts other than the coming Hooker mounts, I would caution you against do so as it's unlikely you will end up with acceptable fitment.
Old 07-28-2017, 05:20 PM
  #213
Toddoky's Avatar
I'm in the middle of mocking-up an LS/TKO install on a Maximum Motorsports 5.0 K-member for the Holley employee who loaned us his car to develop both the Hooker LS and Coyote swap systems for Fox Bodies and thought some of you who like the Maximum Motorsports K-member might want to a few pics of the set-up.
The Hooker engine brackets seen in the photos are the same as for the stock K-member (dual hole pattern in the bracket base plates make this possible). You can also make out the new and coming Holley 302-3 oil pan and the Hooker transmission crossmember supporting the TKO 600 transmission.
This floor will have to be clearanced slightly to fit the TKO as is needed when installing one of those transmissions behind a SB Ford in a Fox Body...or you can buy one of the special low-profile TKO's that are available and they would probably be a bolt-in affair as the extra clearance needed isn't much.
Old 07-31-2017, 02:54 PM
  #214
Toddoky's Avatar
Here's the addition of the headers (orange paint indicates master sample) onto the mock-up with the Maximum Motorsports K-member. Notice the headers clear the K-member stiffener bar supplied by MM with their K-members...that's a nice little extra feature I thi
nk.
Old 07-31-2017, 06:50 PM
  #215
79LS1FOX's Avatar
sure will be glad when they hit the market!!!!!
Old 07-31-2017, 08:25 PM
  #216
Toddoky's Avatar
That makes two of us.
Old 08-01-2017, 04:01 PM
  #217
Toddoky's Avatar
I finished clearancing the tunnel to clear the top of the TKO transmission and can report that it can be done without having to do any cutting or welding. I used a good air hammer it only took me about 10 minutes to massage the floor into the shape it needed to be in. I don't think you'd need to do any clearancing if you used one of the low-profile TKO's on the market. Here's a pick of the Maximum Motorsports steering shaft I mocked-up in the car...fits great.
Old 08-14-2017, 11:01 AM
  #218
ryeguy2006a's Avatar
I can't wait for the release of the 302-3. Just read about this recently, and it looks like I will be ready to purchase in the next 4-5 months.
Old 08-14-2017, 11:08 AM
  #219
Toddoky's Avatar
The 302-3 pan will definitely be a problem-solver for many users.
Old 08-14-2017, 07:24 PM
  #220
dmracing's Avatar
Does the shifter come through the factory location with your mounts
Quick Reply: New Hooker Fox Body Mustang LS Swap System Preview Thread
