New Hooker Fox Body Mustang LS Swap System Preview Thread
#341
#344
They are completely different in both bend geometry and hanger configuration. The biggest difference in the bend geometry is in the inlet pipes of the two systems and the X pipe assemblies, which is due to the transmission crossmember receiver brackets being different between the two applications.
#348
No we don't. The SB Chevy block was mounted in GM cars with either the old-school three bolts mounts that bolted directly to the block and sat on frame stands in the chassis, or the stamped engine brackets that sat on the original clamshell mounts that were attached to the chassis.
#350
No it doesn't, it bolts onto the insides of the frame box rails and you have to drill a couple of holes to enable that. If your car has subframe connectors that encroach into that area you make have to do some prep work to remove any material that will interfere with the mounting feet of the crossmember. They were put up on the Holley website and made available yesterday, I will post some press release info in this thread later this morning.
#352
How is the clearance to the tie rods with the 302-1 pan using the rear stock location brackets? I'm switching to a stroker and would rather run the 302-1 pan than the 302-3
#353
How much stroke?
#355
It sounds as though you are asking in regards to the GM A-Body swap application. If so, the 302-1 pan is not installable with the Hooker Blackheart engine brackets due to its depth being too deep along its front half.
#356
#358
I have no way to gauge the compatibility of any of the Hooker Blackheart Fox Body LS swap components with that specific K-member as it was not one of the aftermarket K-members that I spent time validating.
#360
I'm posting this image of a TH400 install on the Hooker Blackheart 71222016HKR transmission crossmember as an answer for a question that was asked from me by dmracing.
