LS1 Coil cover attaching hardware
Does anyone know where to get the little studs that screw into valve cover that the OEM style LS1 coil covers snap onto?
I just got a pair of LS1 covers from Jegs last night. The right side cover hits the stock 2000 F-body throttle cable bracket. Does anyone know if the Lokar TCB-40LS14 bracket (double tapped for cruise control) will clear the coil cover without trimming? I'm fairly certain the single tapped version would clear, but I'd like the option to add cruise later.
sweet. does anyone have an old set of broken covers that I might be able to buy to salvage the mounting points? I could scab them onto the underside of the covers I bought and probably make something work.
