Foxbody notch lq4 turbo build
Old 12-19-2017, 12:50 PM
  #81
Andler2008's Avatar
I actually started to pull the fuel pump assembly out of my 2003 mustang to put in a Walbro 450. Realized the pump body is much larger than the OEM pump and would not fit into the bucket. Are you planning on using the OEM bucket, or are you going to make a fixture that the pumps attach to?
Old 12-19-2017, 12:54 PM
  #82
Lsxnafox's Avatar
The two pumps might sit in the plasting bucket housing in the tank without too much movement if I just tie them together. Another idea I have is using a through bolt down the middle of the hat to secure the pumps together. I'm waiting on the second pump to arrive I'll probably go with the through bolt to secure them.
Old 12-19-2017, 12:59 PM
  #83
Andler2008's Avatar
Not gunna lie, I saw the threaded rod in one of the pictures and had an AHA! moment. Run a threaded rod through the hat and just make a couple of half circle brackets with the ID being the same as the pump OD to hold them together.
Old 12-19-2017, 01:01 PM
  #84
Lsxnafox's Avatar
Both pumps should fit nicely. Still waiting on the second one to come in.
The fittings should clear the truck floor mounted this way.
Old 12-19-2017, 01:02 PM
  #85
Lsxnafox's Avatar
Yep exactly!!!
Old 12-19-2017, 01:04 PM
  #86
Andler2008's Avatar
Cool deal! Excited to see what you come up with.
Old 12-19-2017, 03:10 PM
  #87
Lsxnafox's Avatar
I'm trying to build the fuel system large enough so I don't have to change things down the road. I'm using a -10 feed to Holley high flow rails and FIC 127lbs injectors. Should be good for 1000 wheel on e85 from the reading I've been doing. Here's on of the y blocks two -8 lines from the pumps to a -10 feed. Still waiting on more pieces to come in.
Old 12-19-2017, 08:23 PM
  #88
2JZFC's Avatar
IMO, making 1000rwhp on E85 with FIC 127s will be a stretch unless you are willing to run them over 90% DC and a leaner AFR. You don't have the option to jack up the FP since the 127# flow is at 4bar. For 1000rwhp you will have to run 20+psi putting the FP at 80psi or more, so make sure the pumps can flow what you need at 80psi and remember to factor in flow loss from the lines, fittings, filters, voltage, etc. Here's what I mean. The Walbro flow chart show the flow as ~87gph @ 80psi / 13.5V. That's about 1070 lb/hr for the 2 pumps. If you use a BSFC of .8 for E85 and apply driveline loss and flow loss, there's not a lot margin left at 1000rwhp.
Not saying it can't be done, just make sure you calculate and know exactly what the injs and pumps will do at the boost/FP you plan to run AND make sure you have at least 13.5V at full load. Just passing on my experiences.
I see my car every time I look at your build. Good luck.
Old 12-19-2017, 08:41 PM
  #89
Lsxnafox's Avatar
1000 wheel is still a long ways away for me. I still need to build the motor with forged internals, build the rear end and tranny. I agree, I'll probably have to upgrade the injectors down the road right now they seemed like the most cost effective way to go. I'm planning on stay around 850hp range for all next year. I'll probably focus on the body and try and get a decent paint job.
Old 12-20-2017, 09:18 PM
  #90
Lsxnafox's Avatar
Christmas came early!!! Got a bunch of fittings and fuel line all -8 and -10 stuff.
Old 12-20-2017, 09:43 PM
  #91
Lsxnafox's Avatar
Forgot to post a video after throwing all the ls2 internals in the motor. Enjoy!!!
Old 12-20-2017, 10:09 PM
  #92
Lsxnafox's Avatar
Last week at the Dyno. Made 670hp and 730tq with 15psi at 4k rpm. Ran out of fuel had to let off.
Old 12-20-2017, 10:27 PM
  #93
Received 3,021 Likes on 2,352 Posts
Bigger injectors, or bigger pump? OR both??
Old 12-20-2017, 10:40 PM
  #94
Lsxnafox's Avatar
I'm completely redoing the fuel system. I was on stock fuel rails and regulator with a single walbro 450 pump and 80s. I'm adding a 450 pump, larger fuel lines, rails, regulator and fic 127 injectors.
Old 12-20-2017, 10:45 PM
  #95
How much ET you think you were cheated out of with the present fuel system?
Oh, it looks like your answer to my question is BOTH! PLUS some stuff! lol
Best of luck, and have a Joyful Christmas and Prosperous New Year!
Old 12-20-2017, 11:07 PM
  #96
Lsxnafox's Avatar
How much ET you thing you were cheated out of with the present fuel system?
Oh, it looks like your answer to m question is BOTH! PLUS some stuff! lol
Thanks!! Merry Christmas and happy new year!!!!
Old 12-21-2017, 05:55 PM
  #97
Lsxnafox's Avatar
The new welds...
Old 12-22-2017, 09:15 AM
  #98
2JZFC's Avatar
Old 12-22-2017, 10:34 AM
  #99
Gunters96lt1's Avatar
Wheels look great!
Old 12-23-2017, 03:05 PM
  #100
Lsxnafox's Avatar
Couldn't use the threaded rod to secure the pumps. They have to sit at an angle so the hose won't kink. The plastic piece that the stock bucket sits in does the job of holding them from moving around too much.
-6 adapter on the stock feed for the return fit on I re used it from the factory fuel rail I was using for fuel supply.
Quick Reply: Foxbody notch lq4 turbo build
