LS3 Install in 68 Camaro
Hi Guys,
I am in the process of getting an LS3 installed in my 68 Camaro. The issue that has just came up is with the motor and Trans moving up an inch and a half the shifter arm, piece that bolts onto the shifter needs to come back that distance. I have the Hurst Blackjack shifter and when I called them it appeared that this is the first time they came across this which I find hard to believe.
Has anyone come across this before and have a possible solution?
Thanks again Steve
Thanks again Steve
With the motor moving forward about 1.25" to 1.5" the shifter arm is to far forward and hits the front of the console. I checked with Hurst Driveline and they do not sell a replacement offset piece that the shifter arm would attach to move it back. I just figured this would be something someone has come across in the past for a TKO600 and might have a solution for.
Another option you could look at is a similar situation that I came across with my LS1/6 speed swap 76 Trans Am. I built a bracket that moved my shifter forward to sit in the factory 4 speed console. You should be able to use the same concept but shifting it rearward.
