Former Rotary Enthusiast
Old 10-20-2017, 12:17 PM
Fuhnortoner's Avatar
Slip yoke installed.
Old 11-16-2017, 09:19 AM
Old 11-16-2017, 01:34 PM
hookemdevils22's Avatar
what fuel pump are you running? I highly recommend not using the C5 pressure regulator - it will dead-head the pump at higher output levels.
Old 11-16-2017, 01:40 PM
Aeromotive Stealth 340lph. What do you mean it will dead head?
Not planning on having more than 500hp to the wheel for now.
Old 11-25-2017, 10:16 AM
Second start.
Old 12-11-2017, 08:01 AM
I've been pretty burnt out on taking pictures lately.
Latest progress:
Radiator/Fan assy and hoses installed. Had to tap a fitting for steam tubes. Sealed it with JB weld.
Drive shaft installed, U joints greased
Added Integra speedo, not perfectly centered but itll do.
Sway Bar relocated
Roughly aligned the front end
Sanded/primered fenders and installed.
Trans cooler and lines installed.
OPS had broken off prior to engine install. Since im not using it, i cleaned it with acetone and sealed it with JB weld.
Aftermarket FPS, OPS, and CTS installed.
N2O Solenoids wired and fully functional
Brake switch wired to relay and fully functional
Lots of other stuff too. Only a few things left to do to get this thing on the road. Need to figure out how im going to install my intake. Theres not a lot of room behind the radiator/fan shroud. Need to install the hood and modify the hood inner panel so it will shut. Need to shorten the trans dipstick. Need exhaust.
Drove it for the first time since the swap last Thursday. Due to open header, and the O2s being 2-3 inches from the atmosphere, the engine loads up in closed loop mode. But when I punch it, this thing rips.
Oh yeah, new water pump. Went to fill the cooling system, and water was pissing out of the weep hole. Swapped the water pump in under an hour.
Old 12-18-2017, 11:44 AM
Got the exhaust done last Saturday. I've been rippin around town all weekend. This thing goes! Im able to light up the tires all the way through 3rd gear, and theyre gummy bears (Proxes R888s).
The 4.10s keep the rps kinda high on the freeway, but im not complaining. Very happy at this point.
Didnt connect a ground on my front harness for the headlamps, and smoked my headlamp switch. So ill need to fix that and I also need to do an intake, which is in the mail now.
Snapped a pic of my exhaust before my phone died. Took them 4 hours. Tough to go over that grannys trans x member.
Old 01-17-2018, 06:13 PM
I haven't updated in a while because I've been out enjoying the car. Oil pressures have been good. I had a harness pin issue that was throwing two 5v circuit codes, that's been fixed. Had to relocate trans cooler. Haven't seen trans temps over 120f. And I burned a M5. Enjoying the car so far. Working on getting the smog done.
Old 01-17-2018, 07:33 PM
Received 3,021 Likes on 2,352 Posts
With your setup, that's what I call a no-miss proposition! lol
Carry ON!!
Old 01-17-2018, 08:59 PM
JROC's Avatar
RX7 + LS motor = Awesome car.
I would love to have a LS powered RD some day.
Very cool build sir!
Old 01-17-2018, 09:37 PM
Thank you gentlemen!
Old 05-04-2018, 04:39 AM
  #32
Still rippin
Old 05-08-2018, 02:44 PM
  #33
Forcefed86's Avatar
Looks good! Had it on the scales yet?
Old 05-08-2018, 11:38 PM
  #34
Thanks man. From other builds ive seen, should be around 2700 - 2900 lbs.
Old 06-03-2018, 09:28 PM
  #35
merim123's Avatar
Which guide did you use to merge the two wiring harnesses?
Old 06-04-2018, 01:37 AM
  #36
Used a combination of https://www.thirdgen.org/forums/ltx-lsx/544768-ls1-harness-start-finish.html and the Ucandoit2 YouTube series
Good luck.
Old 06-04-2018, 07:55 AM
  #37
merim123's Avatar
thanks for the link. I'm comfortable around the LS wiring. I was thinking the merge to Mazda. Looks like straight forward from what I saw on norotors and rx7 club quick research. A very clean convertible (I think 88 or 89) popped up locally by me, so I'm tempted as I've got a spare motor/trans sitting in the garage.
Old 08-29-2018, 09:12 PM
  #38
Old 09-03-2018, 08:03 PM
  #39
Old 09-03-2018, 08:47 PM
  #40
TexasHavoc88's Avatar
Sweet build man! Love the wheels. I've always wanted a rx7. You running the t56 yet?
Quick Reply: Former Rotary Enthusiast
