91 notchback ls1/60e swap
Old 05-26-2017, 05:15 PM
fly pantera's Avatar
Originally Posted by Bowtiedford
make the strange work, night and day difference on shock valving. I had Lakewood, then Strange, and now VariShocks DA, each was a big difference in launch and setup. Yep same here on the 4l60e fits pretty easy. I wish I remember how exactly how we did it. but the stock shifter will work. I'm now also using the stock shifter for my glide.
yeah ive had lakewoods.wanted to give strange a try.il try to make the strange struts work but not going to lose sleep on it.its a stock convertor so its not going to hit hard
Old 05-27-2017, 08:27 AM
bjamick's Avatar
Are you using the aje transmission crossmember?
Old 05-27-2017, 01:29 PM
no after reading reviews decided not to buy it.dont want to spend 150$just to have to modify it. Going with a stock double hump mustang crossmember
Old 05-29-2017, 03:52 PM
5/27/17 8.8 is in.seller SAID it has 3.73s and clutchpaks are good. to much of a cheap *** so well have to see when it does a burn out.
5/27/17 bmr adjustable control arms installed and lakewood 50/50 shocks,also cut one coil off rears.
5/28/17 fuel system is done went with
walbro 255-gss340
mcgaurd fuelfilter-wix33737 backordered
20ft an6 aeroquip hose
4ft of 5/16 fuel hose
rus60940
rus640850(2)
rus640860(2)
rus 610020(5)
Old 05-29-2017, 03:57 PM
wix was backordered so went with microguard from orielys,was only 20$.when wix comes in I'll have it ready to install when microguard quits.
i would recommend going with the screw on adapters instead of the push locks for the an fittings.
Old 05-29-2017, 04:10 PM
motor/trans installed.slid right in together.
picking up some new intake gaskets.
Old 05-30-2017, 06:36 AM
felpro ms92438
Old 06-01-2017, 08:48 PM
AFTER HOURS MOTORSP's Avatar
Lookin good
Old 06-10-2017, 12:17 PM
stock radiator/fans mounted in stock fox location.
stock fox hold downs trimmed.
nipple on stock fans needs to be trimmed to fit
Old 06-10-2017, 07:19 PM
Bowtiedford's Avatar
looking good
Old 06-12-2017, 07:01 PM
gates 22352
Old 06-12-2017, 07:02 PM
  #32
dmracing's Avatar
Is that a fbody radiator?
Old 06-12-2017, 10:22 PM
  #33
yes stock 2001 camaro radiator/fans
Old 06-13-2017, 10:44 AM
  #34
MaroonMonsterLS1's Avatar
Received 1,208 Likes on 775 Posts
I saw you're using the corvette Fuel Filter/regulator. Would you mind giving some more detail on how you're mounting that. Stock lines or aftermarket AN stuff? how are you handling the return?
Thanks!
Old 06-13-2017, 05:23 PM
  #35
Thanks!
post24/25.no pics though
Old 07-04-2017, 06:35 PM
  #36
Old 07-04-2017, 06:42 PM
  #37
car is up and running.still needs small tweaks like
1.change cai design
2.leveling car
3.change the exhaust
4.install 100 shot
5.ud pulley
6.ported tb
7.getting dip stick to work
and theres prolly more.
from the outside and interior its perfect u would never know.
camt wait tille sept to take it to track
Old 07-05-2017, 05:32 PM
  #38
weighed the mustang and its lighter than expected.kinda makes me question there scales?
its a local recycle company that i go to often and they say its accurate to +or-20lbs 2660 curbweight no driver
Old 07-06-2017, 07:20 PM
  #39
Mungface78's Avatar
Man that's light!
Old 07-06-2017, 07:33 PM
  #40
Romulus22's Avatar
Seems a little light compared to a 3035 lb factory curb weight of a 5.0 LX notch. I wouldn't imagine there'd be that much difference to an LS swap? If it turns out to be accurate, hell yeah that's awesome!!
Car looks super clean, I'd love to daily drive that thing.
Quick Reply: 91 notchback ls1/60e swap
