LT1 to LS1 swap
Old 05-20-2017, 03:46 PM
grandprixgt03's Avatar
Default LT1 to LS1 swap
Hi Everyone,
I am swapping a LS1 into my 97 Trans am and I would like to keep my stock k member and use motor mount adapters. Has anyone used the adapter plates and been able to use stock LT1 motor mounts?
Old 05-20-2017, 04:06 PM
Toddoky's Avatar
Originally Posted by grandprixgt03
Hi Everyone,
I don't know if what you're looking for exists, but Hooker offers mounting brackets that allow you to use 4th-gen F-body engine mounts with your stock LT1 K-member.
Old 05-23-2017, 11:34 AM
the_merv's Avatar
I did back in the day, but for the proper position I would use the LS Kmember and Stands
Old 05-23-2017, 11:49 AM
Toddoky's Avatar
The Hooker engine brackets were CAD designed to locate the engine in the same location as the stock LS1 K-member and stands place it.
Old 05-23-2017, 01:26 PM
the_merv's Avatar
I did it back in 2007, way before anything that we have now was out.
Old 05-23-2017, 02:21 PM
Toddoky's Avatar
I understand where you're coming from. Many more parts are available today to make swaps easier than they were 10 years ago.
The following users liked this post:
kwhizz (01-09-2021)
Old 05-24-2017, 02:22 PM
shezam's Avatar
Default Fyi
The lt1 motor mounts will not work, but one nice think on your 97 k member there is a hole on pass side you place the top forward hole of ls1 mount there and you can thread that hole the other forward holes you drill just use a socket with a extension on it . You can also put the nut on top . the rear top you have to drill through both parts of k member . No special drill bit is needed. On the bottom rear bolts I used well nuts. Some call them rivet nuts. I beat them down so the motor mount was flush. To save money all truck accesories and water pump work great . Don't listen to everyones bs about needing f body brackets 2001 1500 work great.
rtraylor (01-06-2021)
Old 05-24-2017, 03:26 PM
the_merv's Avatar
I had the LT1 mounts working with SBC->LS SWap Plates... just didn't line up in the right position. If I had the setback ones it would have worked perfectly.
Old 05-24-2017, 03:37 PM
Toddoky's Avatar
Here's a couple of images of the Hooker engine brackets for the V6 K-members; the LT K-member versions are similar. This configuration puts the LS engine in exactly the same locating it sits with the LS1 stands and K-member, which ensures compatibility with any headers, oil pans and other components that are designed for stock LS1 4th-gen F-bodies.
Old 05-24-2017, 06:28 PM
the_merv's Avatar
Looks pretty much like an LS Stand
Old 05-24-2017, 07:22 PM
Toddoky's Avatar
Yes, that was the goal.
Old 11-27-2017, 08:05 PM
Trackstar's Avatar
This was great info, thanks!
Old 11-27-2017, 08:11 PM
Trackstar's Avatar
This is great info, thanks! I think ill be going this route for my swap
Old 11-28-2017, 08:06 AM
Gunters96lt1's Avatar
I have them in my car. I decided to try them out since i already had a tubular k-member. Have worked perfect for me!
Old 01-06-2021, 07:57 PM
rtraylor's Avatar
Default Will LS truck accessories fit on a 97 LT LS1 swap
will the truck intake and accessories really work
Quick Reply: LT1 to LS1 swap
