Another LS swapped s10 post!
Im sure this has been answers before but, I have been reading all day and haven't came up with a answer that I like. I have a 2000 s10 4x4 that I bought that has a 2006 LQ9 6.0 and it's running the stock s10 4l60e trans. It's a wheeling rig that I have been wheeling for the last 2 years. The transmission finally let go last night. My question is can I use a 4l60e out of a Silverado, or any half ton Chev truck or do I have to stay with the s10 style 4l60. I am unsure if they are the same design
They do have differences but if you get on out of a truck that had a 5.3L or 4.8L you are good to go but if you get one from a little earlier style that had a 350 engine then it will be different. You want one with a 300mm input shaft pretty much and a bolt hole at top dead center of the bell housing but also look at your electrical connector to make sure they are the same
