BMW + 427ci 7.0l + full-on build
Old 09-24-2017, 10:28 PM
350SS's Avatar
this thing is rad...nice work
Old 09-24-2017, 10:53 PM
AAIIIC's Avatar
So I take it you're a fan of the 3-series hatchbacks, eh?
Old 09-25-2017, 11:45 AM
MUL8NO1's Avatar
Default Hybrid combo
The E36 BMW hatch is loathed by most - and that's fine by me - laden with the best of E30/E36 innate design, better Aero than both, and functional utility greater than any, the chassis just lacks what BMW could have done (M Coupe rear half / M3 front half). Well, I've already created one of those... so time to build Ultimate - my favorite BMW chassis coupled with LS 6.0L base + LS3 base heads... and all proper parts to do it right. That's GOT to equate to a healthy 'tool for the job'.
ill find out soon -
Clean work space
Ready for last effort to ready for start
Sleep for a day.... then...!
Old 10-02-2017, 01:54 PM
MUL8NO1's Avatar
Default Fuel plumbing complete, FiTech wiring now
Fuel lines created, routed etc, power steering lines will get created and installed this week, FiTech wiring plugs getting plugged Just 1 of 4 under-Manifold vacuum lines needs a lead on it
FiTech sheetmetal intake and gaskets
Intake Manifold on, fuel injectors plugged in
I need extensions for alternator wiring
Old 11-21-2017, 11:52 AM
MUL8NO1's Avatar
Default FiTech Start
FiTech wiring / schematics caused start delay due to Cam sensor wires being pinned wrong. Taking note of what signals go where at my sensor, and working backwards, found pinout issued. Simple de-pin, re-pin.
Then, with no clear markings etc for Coils Harness, i had both banks exactly backwards. Fixed one side, vehicle at least started... that firing-Side header got very warm quickly - other bank 1-4cy header was not... sooooo, Swap 1-4 with 4-1.... and boom fired up.
Tis quite rev happy given I just popped in a few engine details... and it started.
No more starting until coolant tank shows up and I install the radiator (all cooling system), fan, etc... then get to a dyno to break new motor in and time etc Emulate No One
Getting closer
It’s surprising even to me each time I remove cover how this vehicle has come together DIY style... not one ‘pro’ has touched this build
Old 11-21-2017, 04:15 PM
AAIIIC's Avatar
Can't fool me, I see that Dinan sticker on the intake tract. They did all this, didn't they?
Old 11-21-2017, 04:19 PM
MUL8NO1's Avatar
Default Recycle part = BMW homage’
Im happy to see that got noticed - a segment from an old 540i intake kit that I wanted to piece meal together... my ‘goal’ would be that The Dinan sticker throws off people scent just enough for me to pawn the motor off as “just a 4.4L 540i V8”
Old 11-21-2017, 04:36 PM
Michael Yount's Avatar
Love following this one. My wife's favorite car was her 318ti - from '97-'08. 11 years of driving enjoyment. Brake light switch the only failure in 110k miles/11 years of ownership.
Old 11-21-2017, 05:32 PM
Received 3,021 Likes on 2,352 Posts
VERY clean install! I would love to do a 318ti with a 400HP(flywheel) 5.3/4L60E as a fun little road-runner. Yeah, I like the little hatches too!
Old 11-21-2017, 06:29 PM
Can't be a "fun little road-runner" with a slush box though. (grin)
Old 11-21-2017, 07:30 PM
Still mentally tossing that one back and forth; I DO see your point! lol
Old 11-21-2017, 08:33 PM
  #32
MUL8NO1's Avatar
Default Car fun... is supposed to be FUN!
The joy of functional utility - my Daughter, 4yrs old at the time (now just 6yrs), has her own fully refreshed BMW Hatch I know this is LS-centric /Americana type website - I’m reverent of the fact... I served our country - in 2 branches - I earned the privilege to buy a used German car and fix it up - the V8 car will be pulled by my 2017 L5P GMC 3/4 Ton... so hopefully things balance themselves out
Old 11-21-2017, 09:54 PM
  #33
Originally Posted by MUL8NO1
I know this is LS-centric /Americana type website - I’m reverent of the fact... I served our country - in 2 branches - I earned the privilege to buy a used German car and fix it up - the V8 car will be pulled by my 2017 L5P GMC 3/4 Ton... so hopefully things balance themselves out[/i]
You have NOTHING to apologize for, my friend!
Old 11-22-2017, 06:05 AM
  #34
I know this is LS-centric /Americana type website...
Sure it is....just look at my sig.....LOL! Thanks for your service; but service or not, buy/build whatever you like. Your cars, your money = it only has to please you.
Old 11-22-2017, 04:42 PM
  #35
You nailed it Michael! Cars are only machinery.... obsessed over, loved upon, defended to the death machinery! LOL! Nothing to have to justify or rationalize...
Old 11-25-2017, 03:59 PM
  #36
JankesGTO's Avatar
Default Cage
Your cage is a work of art! Truly amazing build.
Old 11-26-2017, 03:16 PM
  #37
MUL8NO1's Avatar
Default create-every-part-build-causes-stomach issues
Began with a cardboard template to make 3d part.
I have no idea what I’m doing...
This actually looks like something useful!!!
It sure would have been nice to have at least One shop class in my life - regardless, the end result is actually even better than the pics show
3.73 3-clutches, ramped, etc - custom axles, diff hangars tie in with cage, custom brakes, Fikse 3-piece wheels for any street use... blah blah
3 full quarts of Motul instead of 1.5q factory capacity
ive started car 3 times... and am on pause to start again until I install my ‘fancy’ oil cooler, install radiator, locate/install the coolant expansion tank, fresh oil, fresh non-coolant Evans Coolant.
today was add more ‘fancy’ Fluid to diff and finish creating switch panel.
Old 11-26-2017, 03:20 PM
  #38
Is the finned portion of the diff as close to the ground as it appears?
Old 11-26-2017, 06:48 PM
  #39
MUL8NO1's Avatar
Default higher than...
Derale Oil Cooler
Trans and diff fluid
higher than... the V-bands at the header collectors as well as the RTAB on the front tubular SLR Control Arms...
and that said, once I weight balance the car and all corner heights are set, I will be measuring for the actual “Inch” number - that’s a more appropriate answe for you!
Tomorrow, I’ll get the ‘fancy’ Motul Trans Fluid installed
and will Challenge myself to mount my Metal Expansion tank in a unique location - and find a spot for my Derale Dual-Fan Oul cooler to be Fed by this Lingenfelter Oil Cooler Adapter i installed low on block on driver side, aft.
Old 11-26-2017, 06:53 PM
  #40
Had to laugh -- first thought was "saying it's higher than other important bits is kind of like saying Barbara Bush is better looking than Janet Reno"....
Not so bad for a track rat I 'spose. I can still remember getting cross-ways up on high alligatored curbs at Texas World Speedway infield track and grinding a flat off of the drain plug on the oil pan of my ITC car a few decades ago. Sounded worse inside the car than it turned out being.
Quick Reply: BMW + 427ci 7.0l + full-on build
