Just another ls10 408 s485 glide build
Old 09-22-2018, 02:13 PM
  #141
psifanboy's Avatar
well it made its first 35 mile drive into work.
Still currently at 8 psi but damn it feels mean already
Old 09-22-2018, 04:18 PM
  #142
Fuhnortoner's Avatar
So badass
Old 09-22-2018, 07:56 PM
  #143
OEF14vette's Avatar
Good job, nice craftsmanship. Have to let us know how it is when you start turning it up. I have the ms3pro on my nitrous corvette and I was able to get that thing to hook on the ice and cut a 1.8 60' with the launch retard and driveline speed sensors doing their thing.
Old 09-24-2018, 10:59 AM
  #144
psifanboy's Avatar
nice i turned it up to 16 psi saturday night and its a different animal. the PTC TC is really doing its job now. thing hooks up pretty good. I was shaking all nice from the rush lol
Old 10-02-2018, 02:17 PM
  #145
psifanboy's Avatar
got the belt figured out. staying on at 7400 so should be fine. only issue now is a vibration at 70. ordered a 2 degree shim to hopefully fix it.
pics from driving it.
booty pic
I got about 500 miles on it now. its a good runner and feels amazing at 16 psi and i 18 degree of timing. its up on jack stands replacing the blown out shows on the rear and changing all the fluids and try to fix this vibration. on the slip yoke i got a tiny bit of play up and down. its a roller tail with strange roller yoke. not sure if i should have play here or not.
Old 10-14-2018, 10:02 AM
  #146
psifanboy's Avatar
how about a video
Old 10-16-2018, 07:19 AM
  #147
Sick.
Old 10-22-2018, 11:23 AM
  #148
psifanboy's Avatar
well took it to the track for the first time ever. got to make one pass. i spun and it hit 7K off trans brake. when it hit 7K it shifted to 2nd. Went ahead and stayed in in. Pull a 2.4 60 7.70 1/8th at 116. from 23 to 116 i was in high gear lol. this was on low boost. decent data and def need to warm up tires more. Got alot to learn with this thing but it sure is a beast for only teen boost.
Old 12-02-2018, 12:14 PM
  #149
psifanboy's Avatar
Took this thing for a small cruise last night. im freaking ready for race season!
Old 12-02-2018, 12:16 PM
  #150
dmracing's Avatar
Lookin good
Old 12-02-2018, 12:39 PM
  #151
psifanboy's Avatar
last good pic before i tuck it away.
Attachment 715928
Old 12-02-2018, 12:41 PM
  #152
Received 3,017 Likes on 2,348 Posts
Hibernation time?
Old 12-02-2018, 12:52 PM
  #153
psifanboy's Avatar
yup. its been wet and cold here lately and IL loves using salt on the streets so it will prolly be tucked away till it time to start on some upgrades.
Old 12-02-2018, 12:57 PM
  #154
Good deal! Seeya in the Spring!
Old 12-02-2018, 01:24 PM
  #155
Tig
Tig's Avatar
Man, that just looks so damn good. The burnout video was sweet, sounds killer.
Tuck him in so he stays cozy for the winter months
Old 12-03-2018, 02:17 PM
  #156
psifanboy's Avatar
will do haha. turned out really good. very pleased with the way it looks and better yet the way it drives and pulls lol
Old 12-05-2018, 03:46 PM
  #157
psifanboy's Avatar
Did some measuring last night and it looks like i can fit a Frozen Boost type 17 intercooler in between frame rails and a type 100 heat exchanger in the grill area. What are some common tank sizes ppl have been using? Wanted to use the heat exchanger cause this will see alot of street time. thinking a RULE 2000 or 3700 in the tank will do. I really wanted to do the intercooler in the intake but also want to keep my wipers just in case. Ill have to trim my Racers Edge hood back to fit the cowl but itll be worth it im sure. Anyone have a real world experience with the frozen boost set ups?
Old 12-07-2018, 12:16 PM
  #158
rpturbo's Avatar
Been a bit since I have checked in on this. Glad to see you got it out and driving. Making some mph in the 1/8 already. Should be a hell of a ride next year when you really get some seat time.
Old 12-18-2018, 06:27 PM
  #159
psifanboy's Avatar
well guess its time to start working on this pile again. back on the jack stands for a few upgrades. checked out everything under it and all looked good. Will be putting on full exhaust with a Loud Valve that ill control from ECU or switch using mac valve and compressed air. also will be installing the intercooler once i can order one.
Got wipers back in and will just need to trim the hood to fit cowl and wipers
Intercooler location
Jack stand life.
3" exhaust to keep it nice and sleeperish lol
Hopefully when i get back from Florida i will be able to order the intercooler. looks like its out of stock and no clue when it'll be back in stock. will be changing out the brake master to a smaller bore. The 1.125 bore i have in now sucks and pedal is really hard to press. will try the 7/8 next and if that doesn't work ill be going back to power brakes until i can order some fancy brakes.
Old 12-20-2018, 01:29 PM
  #160
psifanboy's Avatar
getting her stripped down even more. got dash and front end mostly part. Drained the E85 and cleaned the filters and running some 93 through it now for winter.
my tiny garage needs all the room i can get out of it so removed that damn shelf out of my way
pre filter had some metal from gas tank sump build.
post filter didnt show any big things but it was nasty also. first filter change on new set up guess u will have that
Ran some 93 for a little and shut it down. will be removing trans cooler to rear most likely to make room for the intercooler. i almost think a 417 would clear the wiper motor. wish i had a buddy that had one i can try one.
will be pulling master cyl soon and wiring in a flex fuel sensor, coolant pressure, rewiring shifter, and cleaning up some of the wiring under dash. come on spring.
Quick Reply: Just another ls10 408 s485 glide build
