Car pulls right, alignment is perfect
I got a foxbody and the car out of no where started to pull left recently.
Thought it was out of alignment but it was not. Put it on the rack two times and it was perfect, front and rear.
Changed brakes, pads and rotors and checked the calipers to see if they were sticking and they were not.
Ball joints seemed good, no clicking or popping when tested with a crowbar
Skinnies were a little worn, both in the inside, outside had decent thread,so i replaced them anyway and it still pulls.
Car has front tubular A frames, LS K member, Strange coilovers.
Any insight would help, thanks in advance
Straight alignment and squared alignment aren't the same.
Are you sure everything is squared?
Rear gear working properly with no sticky bearings or bent axles?
ALL 4 tires worn evenly?
Uneven wear on the front also suggests bump steer issues. You mention Strange coilovers, I think those require C/C plates and bump steer linkages.
yes i double checked that
sorry lol it pulls left. ive driven it on both sides of the crown of the road and still the same
we did that to get an accurate reading
tried both lanes
alignment machine says its all square all 4 wheels.
Nothing changed from a straight alignment to an off alignment, did not touch any suspension
no, just did brakes as well
little update, went to the track and the car went straight down the track and I did not have to fight it like i usually do. Put the car on the trailer and took it home and then drove it around for the next week everything was fine, no pulling left or right except for one time. I took a left turn and when I got done with the turn the car was pulling to the right like it usually does, went about a mile, took a right and the car was straight again. Never had a problem since. I don't have to fight the car anymore like I use to, the road crowns does effect it a little but not like it did (Damn skinnies like to track).
So far it seemed to fix itself? Torque boxes are straight, everything in the rear seems to be good, checked balljoints witha prybar and seem to be fine. I dont know what to think
Does it do it on the same kind/type/smoothness/roughness of road?
My truck was pulling to the right on rough(not bumpy) roads. Turns out the belt was separating inside the tire. When the belt finally let go, I got new tires and the problem went away.
Just a thought
Please let us know what you find.
Just a thought
Interesting, sounds like something was sticking. Perhaps new coilovers just needed a real load to settle.
What do you have keeping the body level?
I've heard anti-roll bars can do something like that due to uneven or too much pre-load. My rear sway bar has adjustable end links and I've been meaning to replace them due to squirrely rear.
