New Edge Mustang - Turbo LQ4/T56
#101
I think I might start a build thread on here for my car finally. I think your build has finally pulled me over that edge haha. Were those samples of the new 3M stuff? Theres a kid around me with a slammed G37 wrapped in that stuff and it looks identical to OEM mystic chrome. It has the exact color flip reaction to light change and it looks so deep. Its amazing how far they have come with vinyl.
#102
On a side note, may be going turbo..... I was thinking S475, anyone else have any recommendations?
#103
Definitely turbo! haha you'll never look back. I think the s475 is a little laggy (I personally don't know) but once they light off they are insane. I think you said this was an lq4 so I really don't think it will be an issue and the limit is pretty much the sky with that one. However it is huge and having a new edge myself I had trouble just fitting my gt45 in the engine bay. I've heard really good things about 78/75 too and as far as size I think it's pretty manageable. Just my 2 cents
#104
Haven't checked back on this thread in a while but I do like the idea of the Cobra tank. I was wondering what others did. Thanks for taking the time on a great write up.
#105
Thanks man. Its been a long ride. I think most people use the stock tanks and either sump it or run them without a baffle. I chose to do it the right way with a stock baffled cobra, that way i dont have to worry about fuel cut.
#107
Attachment 703571Youtube
All im having some problems with my fan hookups. Anyone know what could be the problem... I have them hooked up as so. Wiring is just temporary to see if i get the fans to work right before soldering and heatshrinking. Fan 1 works, but when i turn fan 2 on it clicks the relay rapidly.
Attachment 703571
Attachment 703571
I had trouble with my fan 1 clicking the relay off and on quickly. There was a setting in HPtuners I think It had something to do with the way the ac was controlled previously. Not sure this applies to you I had a 2000 lq4 harness and the same PCM. I'm at work right now so I can't remember exactly what I changed but if you google search it you may be able to find what I did. If you can't I can let you know what I changed when I get to my computer.
#108
try this in hptuners
System > Ac and select ac recirc under fan setting type
I THINK that's what I did I'm not totally sure though. Let me know how it works.
#109
Now i have not made it to testing the engine harness yet, but why are you running three relays with two single fans and no A/C? Am i missing a huge chunk of info? i have wired mine to run two fans off of the single fan 1 relay. I have another relay set aside for the fan 2 control pin just incase i do need to wire it up but i was under the impression that you could just use the fan 1 control to just run the fans all the time. Please correct me if I'm wrong while I'm still working on the wiring lol. Also i will be starting my own thread just to keep me motivated and to be able to keep up with what iv done tonight and ill link you guys if you're interested.
#110
#111
If you have AC then you have 4 relays to work with.
I’ve got 2 relays on mine but I have one single fan with 2 speeds. Low and hi both work but so far the car has never gotten over 198 to use the second fan. I think the stock ls1 is wired with 3 relays but I’ve never looked much into it, mine worked good for what I need so there was no need. I think there are a LOT of ways to wire the fans up.
I am still lookin at different turbos. GT45, 7875, S475, billet VSR 80 mm.
I'm going to cut off the upper radiator support and box it out and make a removable upper with a piece of chromoly 1-1/2" tubing. Then I'll buy a team z lower tubular. This should let me push the radiator and fans up a good 4" or so.
Also ordered a 4.5" Kaenen hood, should be here in about a month or so.
#112
Haha hate it when the damn battery dies on ya!
I think the 7875 should fit without that much modification to the rad support. I thought you said you have fbody accessories so you'll have a lot more room than I did. I'd buy a turbo then try to make it fit. That's what I did because without it your just working in the dark. Helps to hold that sucker in your hands and try to place it. Just my opinion.
#113
Got the car buttoned up for the most part. All thats really left is to install the new McLeod CMC when it arrives, fill trans, replace alternator (I think mine is bad, battery started to die on it tonight with the car ON!), hook up the gauges, RoberD knows what im doing with them. I think yall will like what i have up my sleeve.
Heres a teaser.
#114
#118
I have 2 99-02 harness' that came with the alternators and they're both 1 wire alternators. Brown sounds familiar but not gray. I'll try to take a pic for you today. You tried a different known good alternator from those years? They may be wired different inside so swapping different year alts may not work id stick with another 99-02. Someone else can correct me if I'm way off. Pin 15 on the red connector sounds familiar to me. I'll see if I can get some pics later today.
#119
https://ls1tech.com/forums/conversio...ator-wire.html
This was a good thread on alternator wiring. Theres a pic in post 10 of the plug. I guess just pin B is needed and that's how mine was from factory. I guess the ls1 fbody alt takes a 1 wire just like the truck one does.... I didn't know that. Let me know how it goes.
