1972 c10
Old 11-22-2017, 11:08 AM
Dale Schermerhorn's Avatar
Default 1972 c10
would like help with fuel tank and exhaust trying to but a 5.3 in want to keep tank behind seat and have pump in tank
Old 11-22-2017, 04:47 PM
Received 3,021 Likes on 2,352 Posts
Could you be a little more specific? Try to think your questions thru a little better...
Old 11-22-2017, 04:59 PM
sowbelle's Avatar
I have done this swap
Intank pump hanger is a total you design and fabricate. no one commercially makes a hanger. I used a ebay 255 Walbro pump and went from there. I used a new tank and cut a hole for the my fabricated pump hanger.
The Walbro is noisy. NO REALLY NOISY. I am going to switch to the Deusctewerke (SP)pump real soon.
But nothing oof the shelf right now for what you want to do.
Exhaust is the same for SBC.
Old 11-23-2017, 08:18 AM
showdog75's Avatar
Do yourself a huge favor and put that tank between the frame rails in the rear.
Old 11-23-2017, 09:24 AM
JIMB's Avatar
It would be much easier to run an external pump. I've used Bosch 044 external pumps on a few swaps with great success. Use a C5 FPR. Plump the return line back into the tank.
You can hear the Bosch pump run at idle but as soon as you go down the road you can't hear it over the engine or road noise.
Just .02 worth.
Quick Reply: 1972 c10
