74' Squarebody Gen V L83 - 6l80 Swap
I got a good deal on a 2016 l83 with 6l80 transmission from a Sierra and will be swapping it into my 74' 2wd square. I am just trying to gather up as much info in one place as I can as far as what mounts, trans cross member, headers etc.. that you used to keep everything in stock position as possible. Also tips in doing the harness yourself it someone that can strip it fairly inexpensive, floor shifters etc..
Any information or good links to read up on would be greatly appreciated.
My goal at this point is to leave it stock with exception if headers and a good tune. Also can the truck trans be set up to use touch shift or is it even worth doing.
There will need to be some fabrication to install the drivetrain. Luckily a square body has ton of room and is one of the easiest to swap. Dirty Dingo has engine mounts. I would start there. The trans cross member is super easy. Use a flat piece of metal and mount it to that. The stock exhaust manifolds will work great. 2014 2wd truck headers should work as well. For a power steering mount a few companies out there offer offerings. ICT billet and dirty dingo. Also lswrangler.com has a add power steering pump kit which is what I used. lswrangler.com offers a tap shift module as well and stock harness modification services.
Thanks for all the info. I will have to contact them once we get the actual engine in hand to get them to possibly rework the harness and flash ecm etc...
Hooker/Holley has a lot of LS components, including C10 swap.
https://ls1tech.com/forums/conversio...m-preview.html
The following users liked this post:
Rhaag (02-08-2023)
