Fuel Pump Fitting Help
Old 02-17-2018, 10:16 PM
hcb1700's Avatar
Default Fuel Pump Fitting Help
Hey guys,
so I ask out assembling the tank for my Nova this morning, but have a question about the fitting to the pump. I went with the Tank Inc. fuel tank and their in tank pump. I’m goin. To run AN fittings, so I bought adapter for the pump outlets/inlets.
Are these fittings supposed to screw all the way in?
Old 02-18-2018, 08:29 AM
67Skylark's Avatar
No, they look to pipe thread on the pump end so just stop when they are tight.
Old 02-18-2018, 08:56 AM
bjamick's Avatar
Also with pipe thread you want to use sealant. Either tape or paste type.
Old 02-18-2018, 09:53 AM
DT69cam's Avatar
Make sure whatever sealant you use it is compatible with gasoline.
Old 02-18-2018, 10:21 AM
hcb1700's Avatar
I used Permatex high temp thread sealant. Says it’s good for fuel fittings, so should be good. Thanks for the confirmation guys. Now I can finally get to assembling this car.
Old 02-18-2018, 12:26 PM
Mr.Bu's Avatar
I also have a Tanks Inc. tank and am curious, My pump also had a vent and so did the tank itself. Their kit came with a barbed y to connect them so I did. Is your setup similar? I’ve seen pics where people blocked off the vent on the tank itself for some reason. I know efi needs good venting.
Old 02-18-2018, 01:19 PM
hcb1700's Avatar
Yup, same here. I am planning on using the y fitting that came with it. Just to be on the safe side.
