Big time newbie with 72 Nova and LS Swap
#61
Cool thanks Billy!! Hey btw, where did you get the seal that you used between the fan and radiator? I checked out Lowe's and thought about some window seals but I just used some foam pads from the new trans cooler on the corners but would like to do what you did on yours.
#62
#63
Ok. I have been away for quite a while but I finally got the fan mounted to the radiator. I had been wanting to buy an inexpensive metal bender since late November but was never able to find one so I went ahead and used the edge of a brick and a hammer. They didn't come out too bad. I ended up making U braces and mounted them underneath the radiator support and used the radiator support cover, which was modified a bit, for the top. I also used clips in the fan shroud to bolt to the braces. I still want to reinforce the top with some bolts but this will do for now. I also ended up putting some parts back on the car like the front bumper and cowl panel and windshield wipers. Took it for a test drive. I only have one relay and only used the low speed of the fan and it kept temps under 197° in 85°+ weather.
Now the bads.
1) While on my test drive the car wouldn't shift into 3rd. The engine would just rev but would not shift and go, and I noticed that if I gave it a little more gas then it would race and shift. When I got back home and the car warmed up I checked the trans fluid level and it was on the cold end, I ended up filling up to the hot mark. Drove it back out but was still doing the same thing. Its like it trying to catch the gear but it doesn't. Any ideas what could be the culprit? Converter? Shift Solenoids? I hope I didn't burn anything out for running it low on fluid
One quick note: I was reading on some possible issues and mainly with torque converters. If there is not enough fluid pressure going through the transmission it could cause some issues? As I was trying to figure out how to run the transmission cooling lines to the external cooler in front of the radiator, I kinked one of the hard lines. Could this be an issue or cause of the issue?
2) Upon start up the cold idle oil pressure is about 50-60psi and once it has warmed up, the idle is about 20psi. I did notice the pressure rise on the test drive but the idle pressure concerns me and don't know if it is normal. I even saw it idle down to about 13psi when I was done with my test drive. Is something gone wack with my engine? BTW, the gauge is a cheap mechanical Bosch one. Any ideas?
Thanks
Jaime
Now the bads.
Thanks
Jaime
#64
Ok well I sort of worked the kink out a bit but that didn't solve the issue. Could it actually be the 3-4 clutch pack gone bad?
Anyone have any ideas to either my transmission issue or the oil pressure?
Thanks
Thanks
#65
Ok so from what I have been told from several people and searching different sites, it does indeed point to the 3-4 clutch pack. Yesterday, I started the process of removing the transmission by draining the fluid from the pan and removing the electrical connections.
Here are the results of the fluid. It is a very murky brownish/reddish color and it has a funky smell.
Ok so while I was under there I noticed that the top of the transmission is hitting the floor tunnel. Is it because of the spacer plate under the transmission mount or is it because the body mounts are so worn out?
#66
Oil pressure can be as low as single digits. In fact, I think the C5 warning light comes on a something like 5psi. You have a pretty wild swing, though. Mine goes from just over 40 cold to about 35 warm. Are you running 5w-30?
The 4L60e should easily fit in the Nova trans tunnel. I'd definitely check the body mount bushings, unless your engine mount plates position the engine higher than most (I forget what you got). Regarding the lack of 3rd, you can certainly try solenoids or VSS, since they're easy to do in the car; but my money is on the 3/4 clutch pack.
#67
The trans fluid was new and probably doesn't have more than 50 miles from all my test driving. Transmission seemed fine at first but then suddenly the loss of 3rd gear. At partial/normal throttle it acts like if its in neutral, but if I give it some more gas, it grabs a little bit but feels like I'm in 1st gear.
Thanks for your input hookem!!
#69
As far as the transmission, it has been confirmed that the 3/4 clutches are burned so I'm getting the trans rebuilt. Is there anything that can be done to beef it up a bit?
This definitely set me back a bit since I could have used the money into other parts of the car
#70
Just to be clear there is a 1/2 metal body spacer in addition to the energy suspension poly kit. I went to McMaster Carr and ordered 2 1/4 thick 3.5inch round spacers per side.
Really confusing why the energy suspension kit does not compensate for this.
#71
#72
Yes. There's A LOT you can do to beef it up. Beast or Sonnex sunshell, Zpak clutches, upgraded servos, and shift kit at a minimum. There's much more you can do, but I'd consider those essential for a performance rebuild. Plus you might as well throw in an aftermarket torque converter.
Which shift kit do you recommend? Do you mean like the Transgo 4L60E HD2 Reprogramming Kit?
So here is a list of parts for the transmission. The transmission, btw, is a 2008. Will these work?
Thanks
#73
Thanks
#74
You can use a shop air nozzle to check the gauge accuracy as long as your shop air also has a gauge. I did that with my factory sending unit, reading the OBDII port to see what pressure was reported by the computer. I have a Speedhut CAN-BUS gauge that reads a few PSI lower than what the factory sending unit reports over OBDII (which is extra odd since the CAN-BUS gauge relies on the same signal). I would not be surprised if your gauge is off by a few psi one way or the other.
#76
Ok so I should be getting my trans back on Saturday and just wanted to make sure on the bolts for the bellhousing to engine. I got some ARP bolts and wanted to know if I should apply some anti-seize to them? Also, from what I have read, they should be torqued to 35 ft lbs?
Thanks!
Thanks!
#77
If you are using the factory oil pressure sensor in the back of the intake valley, the screen might be plugged a little.
#79
Ok its been a few weeks since my last post.
The GOOD:
It's been about 2 weeks since I got my rebuilt transmission back on the car and so far so good. Shifting real nice, not pushing it yet though. I finally got rid of my bench seat (you can see it standing up on the passenger side window) and got some Scat Rally buckets installed and they turned out nice, only complaint from which I read from others is they are narrow for larger people. They do fit quite snug and the adapter brackets raise the height of the seat a couple of inches and I'm only 5 7 250lbs so I can imagine a taller person would not like them very much. I still need to drill the four holes to bolt the interior of the brackets. Once i get that done then time for some carpet the interior panels and re-upholster the rear seat to match the buckets. I ordered the cowl hood the same time as the buckets so I'm still waiting for that to come in.
The BAD:
Of course with some progress some other issue pops up
I never noticed any issues with the belt slipping before and I have gone back to my pictures and don't notice it but now I'm getting some belt slippage on the crank pulley and power steering pulley. Seems like right after I got the transmission back and the car running again this issue popped up. See below. The last picture with the arrow is showing to what looks like me is the power steering pulley crooked. I don't know if the culprit is the power steering pulley or the tensioner pulley. When I got the engine last year the power steering pulley was damaged but replaced. From pictures I had seen of the donor Yukon, there was front driver side damage which accounts for the damaged pulley.
The GOOD:
The BAD:
