Silver 99 Mustang LS 5.3L th400 swap
#61
Got my front suspension all cleaned up repainted in part and put back in the car today. Went and picked up a complete 04 stock dropout k-member for the rack and sway bar. Once I get the rack cleaned and installed tomorrow I will switch to the engine projects. It would of been a real **** show watching this old fat guy wallowing around under this car like I used to years ago. Lots harder and slower but still getting there, glad I got lots of time.
#65
The Hi Ram is second hand but unused new still. For about the same price. Can get a new Holley Sniper that is about 3” shorter for close to same price. How would you think the car would run differently between the two intakes ?? Sniper would give the option of a ahorter hood if i later want to do that. I will likely be n/a for a brief time as i want to work out and drivability kinks before introducing the turbo version
#68
I have been concerned about the fact that it lacks the taper that they so proudly advertise along with the sniper. It is BS or ?? That race version looks like it is to catch the guys that cannot stop without spending the most possible. I used to be one. Since this is a dedicated high effort but street no prep project it is not for me. I am sure the hp gain on any of them is negligible to unusable in my application
#69
Looking at radiators and fans. Would you pay more for cherry low miles oem 98-02 fan set than you would the ebay knock off's ?? Based on the **** quality of the Gspot throttle body I have to re machine I feel the old oem stuff is the premium choice...
#71
Spent the morning dis-assembling and re-machining my auction site $66 92mm throttle body. The TPS and the idle air control are both perfectly hand fit now. Used my gunsmith lathe to cut and fit the shaft. And for chucking up a made up dowel mandrel and cartridge roll to hone out the IAC pocket. Both are a perfect fit now. I reassembled it all with loctite red 271 and peened the throttle blade screws. I see no reason why this would not perform comparable to any other 92mm throttle body and cost peanuts and some shop time. Worth the time to save the $$$
#72
What would it cost to rework that "cheap" TB if you had to pay someone to do it? You practically remanufactured it! It's not so cheap now....
#73
I am considering buying a few at a time and doing this work and fitting the two sensors and selling against the straight from china's online. Would be pretty easy to show the issue with a set of calipers and provide the fix. I took it up town to 3 parts stores this morning and tried every brand tps and iac motor available and none were a proper fit as it was delivered.
#76
Started to do a few mods to make the car easier to work on long term. Was gonna stop here and make the top removable before I test fit the engine. Then I saw a car done like this and think I want to just go ahead and spend a day and make it happen. I just like the wide open space to fit stuff in and to work on it. Which way would you go if your car. Is there any downside to option 2 ?? I guess I am trying to find a reason not to do this.
#78
