LS2 E40 swap-- Harness and plug questions
About to start on my diy standalstan harness and I have a few sensor plugs that I can't seem to figure out where they go.
I'd like to have all the connections labeled before I open the pcm connectors and start depinning.
First, I have the cam position sensor, and then a plug that is identical to it with a longer lead... which goes where?
Next I have this random plug on top passenger side... possibly AC??
This one...I'm thinking was to the TBSS fuse box?
Last but not least (for now). I have the DBW pedal from the donor car, but the guy snipped the wires. Where do these need to route to? I know it's controlled within the E40, but....
Thank you guys so much for all help in the past and appreciate your time again here! 😊
ive already got the crank position sensor tagged, it's at the back bottom pass side and had heat shield over it, so I know that one is right.
And I already have the oil pressure tagged as well .this plug in question looks identical to oil, but it's at the very front of the engine, by the maf plug, and oil orepress is very back. It would never reach.
Any other ideas?
Any other ideas?
Any other ideas?
Any other ideas?
Once you've identified the pins at the PCM, it should be fairly simple to look up the pin designations and identify the connectors.
EDIT: Here's a thread on a TBSS forum with E40 pinouts.
I'm an idiot, I wasn't thinking about this coming from an AWD trailblazer SS. The mystery plug is for the front diff actuator!! So those will be pulled (once confirmed when I'm depinning)
Thanks for the help guys. Any insight on what I need to do to wire in the DBW pedal? Where the F*@& do those wire need to go?!?
Again, all of the pinout info is viewable here.
Lower right corner of the image: Accelerator Pedal Position (APP) Sensor = C1 Pins 7,8,22,29, 35 & 41.
Thanks Tipsy! I'll put this to good use, very helpful.
