4L85E in 68 chevelle
Old 12-03-2018, 03:46 PM
376shovel's Avatar
Default 4L85E in 68 chevelle
Hello, I currently have a 2004R in a 1968 chevelle. Looking to move to a 4L85E I found from a junkyard. What is needed to physically fit it into the car in terms of a crossmember? Can I use my stock one just flipped around? I know I need to shorten the driveshaft and change the yoke. Anytging else I'm missing? Thanks dudes.
Old 12-03-2018, 05:21 PM
Received 3,018 Likes on 2,349 Posts
Measure from the mounting face to the mount pad and you'll know. At least you won't have a TV cable to kick around any more....
Old 12-03-2018, 07:20 PM
461rat's Avatar
I just finished a 4L80E and 6.0 into mine, Fit great with the Holley brackets, and headers, with the forward biased engine mounts. (which are key to getting it to fit in stock tunnel)
Its a tight fit even with all of that, and even a little massaging around drivers rear sensor on trans, and a little on the top right of the trans. I also used Banjo fittings for the transmission lines to allow more room.
Old 12-05-2018, 08:14 AM
376shovel's Avatar
What about the speedometer options for this?
Old 12-05-2018, 09:59 AM
Project GatTagO's Avatar
Received 1,386 Likes on 875 Posts
Are you asking for options to retain the stock cable speedometer? If so, this is an option:
http://www.dakotadigital.com/index.c...rod/prd886.htm
Andrew
Old 12-05-2018, 06:11 PM
376shovel's Avatar
Thanks for the tips. I secured a 2002 4L85E today. I plan to replace the whole valve body and put the HD2 kit in as well.
What is the difference between 99-03 valve bodies and 04+ valve bodies?
Old 12-05-2018, 08:20 PM
jimmyg's Avatar
Why change the valve body? Messed up? I’d put the hd2 kit in and rock it
Old 12-05-2018, 08:29 PM
376shovel's Avatar
well I figured it's cheap insurance, plus it replaces all the solenoids, check *****, and the actuator feed valve I keep hearing about that is worn after 100k. I think this 124k transmission is actually 221k because I ran the cars vin on mycarfax... I plan to do the HD2 kit, but figured I'd replace as many wear items as I can while it's out. If I do get a rebuild kit, what is a good kit that isnt $900? Trying to stay cheap here.
