4.8L crank into L33 5.3L Aluminum Block - LS1TECH - Camaro and Firebird Forum Discussion
Notices
Conversions & Hybrids LSX Engines in Non-LSX Vehicles
Old 01-02-2019, 01:48 PM
Arrow 4.8L crank into L33 5.3L Aluminum Block
Hello to all LSX engine builders and awesome wizards of the engine building world! I have an ambition of building a LSX S10/Sonoma, with regards to building the engine first.
My Idea: Take a 4.8L crank and apply it to a L33(or similar) aluminum block for the least amount of weight and the smallest engine displacement for the best MPG to make a fun small truck daily driver and highway cruiser.
Goal: 25+mpg(30 if possible) highway and 300HP/300TQ (would be willing to lose a bit for better MPG) with full accessories A/C, P/S etc
Target Vehicle: 2000-2003 Chevy s10 or GMC Sonoma
My Questions: 1) Is this possible?
2) Is this worth the trouble and $ of changing the crank?
3) From an engine builder's perspective what would you recommend?
Thank you for your assistance
Daniel
DanCannon27 is offline
Old 01-02-2019, 02:17 PM
Restricted User
The 4.8 doesn't really get better mile than the 5.3. Shorter stroke does strange things for efficiency. I don't feel that its worth the hassle.
JoeNova is online now
Old 01-02-2019, 02:22 PM
Ok thanks for the input. All 4.8L are iron blocks and with the 4.8L crank in the aluminum L33 (100pounds lighter) I figured the weight alone would give it a boost in economy.
Old 01-02-2019, 02:32 PM
Restricted User
100 lbs vehicle weight reduction might be good for a very very slight increase in mileage.
Old 01-02-2019, 03:04 PM
I would just go with an alum 5.3. Small cam. Gear it right. Make sure the tune spot on for 87 octane gas. I bet you would get 25 mpg 60 mph easy. My 15 Silverado crew 4x4 with a 6.2 knocks down 21-22 mpg at 60 mph on a regular basis. But it requires 91 Octane gas.
LS1 TJ is online now
Old 01-02-2019, 03:44 PM
Project GatTagO's Avatar
I would keep it 5.3L (gen 3 go gen 4 aluminum blocks), keep the stock cam and intake. That will get you the best mileage. With the stock cam you want to gear it so that it goes down the highway around 1600-1800rpm at 75mph. This is generally fast enough for a road trip and with stock cam and intake these engines are very happy there.
Andrew
Project GatTagO is offline
Old 01-02-2019, 03:47 PM
Ok good info guys thank you. I am a previous owner of a 1998 Camaro SS 6spd manual (Aluminum block LS1: 5.7L) and I was amazed that I was able to achieve 27/28mpg on highway cruising at 70mph.
This ambition came from a theory of a lighter vehicle and smaller displacement. I have also thought of using an electric water pump to get another slight boost in MPG.
Old 01-02-2019, 03:51 PM
Your trading solid reliability for questionable gains...not something I would mess with for maybe .001mpg.
Andrew
Old 01-02-2019, 03:54 PM
truckdoug's Avatar
4th gens got good mileage because they had a very low drag coefficient
same motors, trans and gears in even a small pickup like an s10 is gonna lose ~10mpg at 70mph
truckdoug is offline
Old 01-02-2019, 04:05 PM
Michael Yount's Avatar
Routine 19-21 mpg city, 25-27 mpg highway in a 3200 lb (w/me in it) brick powered by stock 6.2 LS3. The weight savings will do virtually nothing for highway mileage; might help a hair around town. Stock 5.3L should get you close to your goal if geared properly and not running 80+ mph.
Michael Yount is offline
Old 01-02-2019, 04:14 PM
What if,, or Why not just use the new 4.3? 300ish HP and all aluminum.. and they are surprisingly cheap. (Who wants a V6? LOL)
Gen 5 tech, no relation to the Pre-2014 4.3 and it fits in the hole.. I've been wondering how it would handle a single turbo..
The full size quad cab rental Silverado with me rodding it to Montana and back form Oregon, it got about 20 at 85 on the freeway,
mid 20's at 55/60 Has a nice growl, and might have taken the Silverado to about 100 fairly easily.
pdxmotorhead is online now
Old 01-03-2019, 10:50 AM
You'll need the 4.8 crank, rods, and pistons (flat top) in order to maintain the correct deck/compression ratio. No special parts or machining required.
Andy1
Andy1 is offline
Old 01-07-2019, 02:52 PM
I did this. I could only find a bare l33, all the completes at the time were more than i wanted to pay. so i bought a 4.8 and swapped the guts into the l33. i chose a 4.8 donor for the economy.
it worked fine but eventually i switched to a 5.3. i agree the 4.8 isnt worth it for the economy, if all you can get is a 4.8 for whatever reason thats fine, but a 5.3 is better in my experience.
TrendSetter is offline
Old 01-07-2019, 02:54 PM
i saw 18-19 mpg best case in my s10 with a bed cover, t56 in 6th gear on the highway. motor was 4.8 with a tu0 cam(216/216). it lit them up in 4th at any speed once boost came on though
About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
