starting a gbody build
Old 01-12-2019, 12:29 PM
bigassogre's Avatar
a 7.5 gm probably wouldnt last one rip. a stock exploder 8.8 would last a couple years, a built one probably forever...all depending on your tires and launch
car will be a built turbo iron block 6.0/upgraded 4l80e/upgraded 8.8 btw, i got u some pics of that interior
Old 01-12-2019, 01:01 PM
truckdoug's Avatar
tight I sent you my phone and email in that pm.
Old 01-12-2019, 09:35 PM
bigassogre's Avatar
8.8 is cut down and bolted in the car.
Old 01-12-2019, 09:47 PM
bigassogre's Avatar
Old 01-12-2019, 09:48 PM
bigassogre's Avatar
Old 01-12-2019, 09:54 PM
bigassogre's Avatar
weight of the car is on it. its centered within 1/8\" inch. i think it came out pretty good. im leavin the ebrakes off since its an auto anyway and will get a spool. keepin the rear disc setup. traded up a couple more 8.8s the other day so i may build another one since my jig is setup for it now. now to get wheels and tires on the rear.
Old 01-12-2019, 10:29 PM
truckdoug's Avatar
hell yeah that's the kinda progress I like to see!
Old 01-13-2019, 07:32 AM
bigassogre's Avatar
wheels. tires. engine. trans. hood. coming soon
Old 01-14-2019, 09:20 PM
bigassogre's Avatar
l
look at that sexy beast
Old 01-16-2019, 08:55 PM
bigassogre's Avatar
mockup
Old 01-16-2019, 10:19 PM
truckdoug's Avatar
hell yeah
Old 01-17-2019, 04:48 PM
  #32
bigassogre's Avatar
tuckin those deep 15x10s
Old 01-21-2019, 07:34 AM
  #33
bigassogre's Avatar
well the fmic tucks in there nicely. engine is sat in there for measurements. gotta build a trans crossmember for the 80e
Old 01-23-2019, 05:47 AM
  #34
NCDEERE's Avatar
While you are in the engine bay swap a steering shaft from a 95-98 Grand Cherokee. It uses u joints and takes a bunch of slop out of the steering.
Old 01-24-2019, 05:53 AM
  #35
bigassogre's Avatar
yea i had planned on doing that. but mainly bc i was thinkin that they are also a little more compact and i might gain a little room
Old 01-24-2019, 05:58 AM
  #36
bigassogre's Avatar
engine and trans are in there. engine is bolted in with lsx innovations adapter plates to use the stock clamshells. trans is just ratchet strapped up until i build a crossmember. im not payin that crazy money that gforce or anybody else wants for one, its like $30 worth of steel. i stuck a truck hotside on it with my billiet 80mm just to see if it would be close to workin. its about 3" too high so i guess ill start workin on the hotside for this car after i get the trans crossmember built
n
Old 01-24-2019, 05:59 AM
  #37
NCDEERE's Avatar
They are a lot smaller in diameter, especially at the steering box end.
Old 01-24-2019, 08:02 AM
  #38
408GT's Avatar
Looking good man.
Old 01-25-2019, 05:20 AM
  #39
bigassogre's Avatar
Originally Posted by 408GT
Looking good man.
thanks
