Holley 302-3 Windage Tray Cut
Old 02-16-2019, 07:35 PM
Slow Z28's Avatar
Default Holley 302-3 Windage Tray Cut
Long story short, quick question, whatever you want to call it, I got a bit overzealous with the cutting on the windage tray. I didn't pay attention to the orientation of the pan in the instruction and made the oil pick up notch on the wrong side, so now I've corrected it on the right side. Also with the center notch, I went a little deeper than what I've seen others, and that went through one of the openings and I wanted to confirm if how I have it is ok. If not, its a cheap thing to replace and redo again.
Top view of mine showing the oil pick up notch on both sides.
Deeper than what I've seen cut and you can see it opened up that slit
what i've seen others as the "correct" way with th center clearance not as deep as how I did it.
Old 02-16-2019, 09:26 PM
Received 3,022 Likes on 2,353 Posts
Not worth worrying about.
Old 02-16-2019, 10:00 PM
tfi racing's Avatar
Just give it a bit of de-burring and you will be fine.
