GMPP fuse block and ecu mounting ideas 2nd gen Fbody
I am in the midddle of swapping a connect and cruise LS3 into a 1978 Firebird and I can’t seem to find a good place to mount the GMPP fuse block and ECU. I want this to look clean and I would like to not have to hack up the harness to lengthen and shorten the harness if possible. I am running a vintage air setup so the pass side of the fire wall is available but I would rather not have a ton of wires looped around over there if possible. Again looking for clean and easy and if you have pics of what you did even better.
If your harness is long enough you can place your ecu under the dash. I placed mine on top of the tunnel and built a console to cover it all up. Seals-it makes nice pass through grommets. My harness passes through right beside the passenger head.
