5.3 4l80e in gbody malibu
Old 03-05-2019, 04:40 PM
78Chev5.3's Avatar
Default 5.3 4l80e in gbody malibu
I have already ls swapped a malibu with a 5.3 4l60e combo. Going to upgrade to a cammed 5.3 and a 4l80e. The trans I had gotten from a 2000 chevy 3500 truck with a 5.7 engine. Wondering what I would need to make this work as far as flex plate, driveshaft, etc. I'm going to build a crossmember. Any feed back would be great!!
Old 03-06-2019, 02:23 PM
jweb's Avatar
I just finished a 5.3/4L85 swap in an '86 Cutlass. Here's the flexplate I used
ATP Z-270 ATP Z-270
I had trouble with the driveshaft since the trans came out of a box truck. I had to change the tail housing and use a counterbored yoke. You won't likely have the same issue.
Old 03-06-2019, 02:54 PM
1964SS's Avatar
I believe a 2000 3500 would have had the 6.0 LQ4 engine which has a longer crank snout so you would need a crank spacer on your 5.3 to bolt up to that 4l80e.
Old 03-08-2019, 06:26 AM
bigassogre's Avatar
2000 model 1ton trucks came in both bodystyles.
Old 03-08-2019, 06:57 AM
78Chev5.3's Avatar
My engine and trans came from the older body style. 5.7 motor
Old 03-08-2019, 08:31 AM
ijimmy's Avatar
Um , what does this have to do with trany fitment ?
Interested as I have an 96 2500 with an l31 and 4l80 , that wants to be repurposed behind an ls motor
Hopeing its just a converter bushing , like when installing a turbo 400 , and that the computer will "jive" pl1 or e38
Old 03-08-2019, 09:35 AM
78Chev5.3's Avatar
I have a 4l80e that was mated to a 5.7 350 and I'm looking to put it behind a 5.3 ls just not sure of what all I needed to do this. Not many answers have been given
Old 03-08-2019, 09:49 AM
ijimmy's Avatar
If you have a dished flexplate [pretty sure all 5.3s do] , I think this is all you need
https://www.ebay.com/itm/LS-Torque-C...8AAOSwgLdaownB
Old 03-08-2019, 09:56 AM
78Chev5.3's Avatar
https://www.ebay.com/itm/Flexplate-f...9-c71b98c8806c
I ordered this. The 5.3 flexplate only has 3 mounting holes for the converter
