Turbo Ls Foxbody starter wiring questions?
I am getting around to figuring out how to wire everything and I am stuck on the starter. I made this rough diagram that doesn't use the ford solenoid, but I don't know if it is correct or if i should run the ford starter solenoid. Any input is welcome.
If you are using an ignition switch, just connect the solenoid wire to the start terminal.
And I think ideally you want to run power from the battery, to the starter, to the alternator, to the fusebox. But it probably doesnt really matter.
