4.8/5.3/6.0 1 wire oil pressure gauge resistance
So I've been searching for some resistance info on the 1 wire oil pressure senders in the early ls truck engines and have been having trouble finding what I needed. If your looking to hook up a stock cluster op gauge here's some info I found in a service manual for a 2001 Silverado 5.3. If it's already been posted then I suck with the search functions, if not hope it helps somebody in the future.
That's some good info! I'd love to see the same thing for a 98 fbody 3 wire temp sensor if you have the ability to get that info too? I see where there are ohm to temp charts out there for the range that you may see during operating temperatures, but nothing I've seen for a 98 Fbody car.
https://ls1tech.com/forums/conversio...questions.html
