My 64 build
My 64 build
Here's a few pics of my 64, A couple early on, skipping all the many hours of body work
Fresh coat of epoxy, body shutz and color
Boxed and powdercoated frame with drop spindles and UMI A-arms
Battery box in the trunk
The following users liked this post:
1964SS (06-21-2019)
cool car. i love the battery box. i made one out of a .50 cal ammo can, and a lid modified to go on the side from a .30 cal box for an old honda i had. what is that color of the car? nice color.
Thanks, Solar Orange, its a Audi, VW from the mid 2000's. With a lot of pearl
Not the best fit, but good enough
A little more wiring complete with the dash in, its going slow while trying to hide as much as I can. Long way to go.
LSX inovations for the adapter plates with the original frame mounts, Speed engineering for the headers, inexpensive and they look nice but will eventually have to dent one of the tubes to clear the steering shaft. May make a change somewhere just not sure.
A little update, after procrastinating for several months I finally sent my pcm to get flashed for my first start up. I’ve had this 6.0 since 2014 purchased from a salvage yard not having heard it run. I did the harness per the LT1swap site which also did the flash. After about 5 cranks it started right up. It threw 1 code, temp sensor, but not having a radiator or coolant that was expected. Needless to say I was very happy, no obvious “bad” noises. Couldn’t load the video but here it is as it sits.
Knocked out a few things lately, radiator and fans are in place along with fluids. Brakes and MC are in place, tires and wheels are ready to install as soon as brakes get bled, driveshaft measured and ordered, machine shop friends are handy. Ordered up Pypes exhaust, just waiting on a brown truck, Pic is just before tires were mounted.
Mikes64 (12-23-2019)
A few more things out of the way, or at least the steering shaft is. Don’t like dinging the headers. Brakes have been a bear to bleed but seem good, hope I don’t regret the manuals. Tires and wheels mounted, going to mock up the exhaust next.
