Notices
Conversions & Hybrids LSX Engines in Non-LSX Vehicles
any advice on what eletric fans to run ?
Old 07-08-2019, 12:10 PM
Default any advice on what eletric fans to run ?
im having a bit of issues finding a good fan that will keep the car cool enough. Its a street car so yes it will see traffic and yes its miami hot weather! the radiator i bought is this one
https://www.summitracing.com/parts/g...s/?prefilter=1
Core Width (in): 21.000 in.
Core Height (in): 15.470 in.
now i had a pair of SPAL fans but they were 12" which obviously are too big for the radiator itself! and i thought maybe the Taurus fan but those are even bigger!
any help?!
its for a 240sx 5.3 turbo.
panda240ss is offline
Old 07-08-2019, 12:21 PM
I would have to measure the exacts, but I have a ford focus fan from a focus with A/C. Its dual fan and about that size. It cools my 5.3 well enough. They are kind of popular for ls conversions i guess. Cheap, moves a lot of air. They're a 50 amp draw with both on...
Found this...You could probably trim the plastic tabs off. I drilled holes in the shroud towards the inside and use the ties that go through the radiator and pull it tight to it on mine.
You could get two 10" spal fans... But all the dual units at going to be at least 21"-23" wide. You could let it hang over an inch on the sides...cant imagine it would hurt it.
LetsTurboSomething is offline
Old 07-08-2019, 07:58 PM
chuckd71's Avatar
Flexalite 295. PWM is there so all you have to do it supply it power and set your temps. Can add switches or a/c input as well.
Never mind, looks like it's an inch taller and wider than your rad.
chuckd71 is offline
Old 07-09-2019, 08:55 AM
1964SS's Avatar
That's a very tough size to find enough cfm for a v8. I've been extremely happy with derale fans. Maybe look into a 14" or 15" and make your own custom fit shroud. Here's a nice 14" two speed derale. https://www.summitracing.com/parts/der-18214/overview/
1964SS is offline
Old 07-09-2019, 09:26 AM
its funny you put that fan, because i was looking at that fan! lol. i mean most fan for "v8"s are 2000 cfms!
Old 07-09-2019, 10:37 AM
CattleAc's Avatar
Too bad those focus fans won't fit, I think they flow about 2500 cfm...I've seen a couple of the C3 Corvette guys use them.
CattleAc is offline
Old 07-09-2019, 10:39 AM
So usually thats what the cfm should be like 2k is good enough?
Old 07-09-2019, 01:54 PM
1964SS's Avatar
Generally you want about 2500cfm for a V8, but I have heard people use the 2100 derale and it cools 420hp with ease. I have the derale dual 13" on my chevelle which move 4000cfm and it's a bit much. It can drop my temp from fan on to fan off in about 2 minutes even with the AC on.
1964SS is offline
Old 07-09-2019, 02:49 PM
Hey, better way too much than not near enough....
G Atsma is offline
Old 07-09-2019, 03:41 PM
Project GatTagO's Avatar
I would consider the C7 fan. It has the PWM controller built in, which is awesome with the Holley EFI. The mating connector is available from Spal. The fan is rated as 600watts and will cool awesome. Oh and it is about $200.
Andrew
Project GatTagO is offline
Old 07-09-2019, 03:51 PM
CattleAc's Avatar
Originally Posted by 1964SS View Post
Generally you want about 2500cfm for a V8, I have the derale dual 13" on my chevelle which move 4000cfm and it's a bit much.
Yeah...I have the dual fan "Windstar" module on my wagon...a little bit over 4400 cfm...never had the second fan come on. (They do sound like a Piper Cub on take off if I turn them both on at once!!)
CattleAc is offline
The following users liked this post:
kpeters59 (07-10-2019)
Old 07-09-2019, 03:53 PM
i might have to ghetto rig this one lol
Old 07-09-2019, 04:23 PM
Sigh...
Andrew
Old 07-09-2019, 04:26 PM
Originally Posted by Project GatTagO View Post
Sigh...
Andrew
CMON andrew what else can i do! i need cooling fans asap!!!
Old 07-09-2019, 04:32 PM
I said what I would do...Do it once, do it right...
Andrew
Old 07-09-2019, 04:34 PM
i didnt see that post where can i get c7 fans? and size?
Old 07-11-2019, 07:36 AM
ddnspider's Avatar
Figure out how to fit Derale 16925's.....no cooling issues any more, even with AC and an iron block, they work awesome.
ddnspider is offline
Old 07-11-2019, 08:41 AM
Since you are going with OEM EFI, the C7 fan is not a good option. The C7 fan requires a PWM- input from the ECU because it already has a built in speed controller. This would be possible to do if you were going with the Holley EFI systems (some GenIV ECUs also have PWM output for the fans).
Andrew
Old 07-11-2019, 09:53 PM
Michael Yount's Avatar
If you ghetto rig it, throw a fire extinguisher in the car.
Michael Yount is offline
Old 07-11-2019, 10:18 PM
kingtal0n's Avatar
I used this fan in a bunch of engine swaps (2jz, rb25, sr20, lsx)
new from ebay very inexpensive
The key to making a powerful set of electric fans work properly is to fully vacuum-seal the shroud to the radiator so the air is forced to go through the rad.
I take the rad out and cut up some flexible heat-shield materials (basically free reflective from junkyard, pliable, insulating material) to seal the edges. You have to get creative when trying to fit weird fans to weird radiators.
edit: Also I just remember why 'that' fan. Yeeaaars ago on zilvia.net somebody flow tested this fan and about ten other popular fans, including famous taurus fan and Flex-A-L220. And these Altima units came out on top, with taurus next in line.
kingtal0n is offline
About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
