Procharger/LS1/1970 Camaro - has antone done this?
Hello-
Has anyone here installed a procharger on an LS1 motor in a 1970-1981 Camaro or Firebird?
My main concern at this point is will this set-up fit under the stock hood.
Thanks.
Thanks.
ls1
are you sure a stock LS1 fits under a stock 70 style camaro? I'm interested in putting a LS1 into my 73 camaro, but just haven't started yet. I do have one on a skid if you need a measurment. As for the procharger I'm not sure how that will fit. Do you already have this motor in your car? I could use some tips on the installation myself.
Jeff
Jeff
I believe it should fit under a stock hood. The supercharger would be more towards the side rather than on top of the engine.....look at how the procharger kits fit in 4th gen F-bodies.......It might be a tight sqeeze but should work....That would be a neat setup in a 2nd gen. I hope to put a magna charger in my 71 once I get the ls1 snug in there...i might have clearance issues though...
Sharp1...yes the LS1 fits under 2nd gens its been done and I am in the process of doing this swap
you just have to look at all the different gen 3 applications for the procharger. They all sit relatively low, so you just need to get the one that will clear frame rails and steering components.
1970, 19701981, add, camaro, charger, conversion, fit, hood, installation, ls1, pro, procharged, procharger, swap
