Conversion folks please list your conversion in here
Old 10-24-2017, 05:51 PM
  #1701
Kkern's Avatar
Originally Posted by G Atsma
Now THAT looks like a cool ride! AND I bet it runs like one!
Thanks, still doing shake down but she runs pretty well. I was going for mid to late 60s style with "modern" powertrain. Just picked up a t56 and ls3 top end. I'm hoping for 450 wheel N/A
Old 11-11-2017, 02:05 AM
  #1702
InTheRough's Avatar
Not converted yet. I just picked up a 2002 Camaro SS donor car to swap the LS1 and T56 into a 1969 Datsun Roadster. I look forward to getting some information but, being a new member, my posts are being limited.
Old 11-15-2017, 06:36 PM
  #1703
dtbenner's Avatar
Default LS-3 480/4L70E in my 61' Impala
Finally finished my LS-3 install and it runs and drives great.
I had a lot of inspiration from seeing what others have done on these forums.
Chevrolet Performance sells a great package and the 4L70E is programed with solid shifts. It chirps the tires on the 1-2 upshift on WOT and it fit my car without modification to the tunnel.
Combined with a 9" custom fabricated rear end and heavy duty driveshaft from Inland Empire driveline it all works together.
I hid the engine and transmission ECU's inside the car to keep the engine compartment clean.
Thanks to everyone here on LS1 Tech for the info you post.
Darrell Benner
Fremont CA.
Attached Thumbnails Conversion folks please list your conversion in here-img_0400.jpg
Old 11-22-2017, 01:03 PM
  #1704
ecoman35's Avatar
Default 72 chevelle LQ9
Finally finished my 72 chevelle after 2yrs.
LQ9 out of 2003 escalade
SRD custom camshaft
trunion upgrade
flowmaster headers
200 4r
2800 edge converter
4:10 12 bolt
Did 375 hp 400 tq on the dyno
Old 11-22-2017, 05:36 PM
  #1705
Received 3,017 Likes on 2,348 Posts
NICELY done!
Old 12-05-2017, 05:21 PM
  #1706
JosR's Avatar
Default Default Conversion folks please list your conversion in here
1967 Chevelle Malibu
New LSA/4L85E GM Connect & Cruise
Will post pics as I go including part numbers that work as there have been a few posts of some amazing builds but I'm still uncertain on part numbers for Accessory drives and AC mounts for the LSA in an a body..
Thanks, Jos
Attached Thumbnails Conversion folks please list your conversion in here-img_0706.jpg   Conversion folks please list your conversion in here-img_0828.jpg
Old 12-15-2017, 10:13 PM
  #1707
dublingto's Avatar
I have a 1967 Pontiac GTO convertible with a 525 hp LS 3 hooked to a T56 magnum 6 speed Manual trans. Also For 9 inch with 3.89 gears. Used the Holley accessory drive brackets and Holley 302-2 oil pan. Have about 2000 miles on it and enjoying every mile! Got to figure out how to post pictures on this site.
Old 12-15-2017, 10:26 PM
  #1708
Any hassles using the Holley parts? Did you use their engine and/or tranny mounts?
Old 12-19-2017, 05:19 PM
  #1709
Kkern's Avatar
holley makes real quality parts, only issue I ever had was the damn power valves popping on the carbs.
Old 12-19-2017, 09:55 PM
  #1710
Backfiring thru the carb??? It'll do it every time
Old 12-20-2017, 06:33 PM
  #1711
B52bombardier1's Avatar
Hello,
My conversion is using a model year 2000 Chevy Silverado LM7 VORTEC truck motor and its 4L60E transmission into my 1970 El Camino. Rust repairs have been my focus since acquiring this vehicle last April and she had been parked since about 1983-84 according to its last Texas inspection sticker and plate decal. All rust repairs have been finished and I'm hoping that next month will be a big month for the front brake disk conversion, coil overs, front suspension rebuild and the installation of the Dirty Dingo LS engine mounts.
I'm hoping that February will allow me to begin test fitting the motor and trans. Fingers crossed and hopeful.
Rick
Old 12-22-2017, 09:17 AM
  #1712
Ncobillas's Avatar
In process: 1999 lm7 5.3/700r4 in a 1989 scsb 2wd 1500.
Old 12-26-2017, 08:30 PM
  #1713
nova66mussl's Avatar
Default 66 Nova wagon
1966 Nova 2 door wagon
2003 LS6/4L65E
by https://www.flickr.com/photos/154841817@N03/, on Flickr
Old 12-30-2017, 03:47 PM
  #1714
MBrownz71's Avatar
In progress.... 72 C-10 deluxe swb
2015 L99 DOD delete Texas Speed VVT-1.2 cam, future Maggie. 6l80e
Old 01-03-2018, 08:32 AM
  #1715
lstvr's Avatar
1998 TVR Cerbera, 416CI LS3, undergoing an engine rebuild/upgrade to a 419CI, with AFR 245 Heads, manual TKO 600 Gearbox.
Old 01-03-2018, 04:14 PM
  #1716
autopat's Avatar
Originally Posted by autopat
66 Suburban-
65 C-10 Short wide big window-
LM7/4L60E
LQ4/4L80E
Still don't know which one is going where, just scratched the surface of these swaps, just have the trucks and the engines, no idea where I want to go yet.
Pat
So, I just picked up another LQ4, so now both trucks will getting the 6.0’s. I think I’ll rebuild the LM7 for the wife’s 261k mile 00 Suburban. Nothing wrong with it, but still 261k! Might as well since I have it. Anyone done the reluctor wheel swap?
Pat
Old 01-03-2018, 04:28 PM
  #1717
Why would you need the reluctor wheel swap? All your engines are Gen III.
Old 01-03-2018, 08:32 PM
  #1718
autopat's Avatar
The LM7 is an 06.
Pat
Old 01-03-2018, 08:39 PM
  #1719
The LM7 is an 06.
Pat
And the LM7 you have has the later wheel? I believe it was an overlap year.
Old 01-04-2018, 08:34 AM
  #1720
autopat's Avatar
I honestly haven’t looked at the color of the sensor yet, but so far the resounding answer is 06 and up are all 58X. Just wanted to have the info on hand before I get started, ducks in a row if you will.
Quick Reply: Conversion folks please list your conversion in here
