LS1 Into Early Bronco Info
Old 03-11-2003, 11:14 AM
Broncosaurs's Avatar
Default LS1 Into Early Bronco Info
I am starting to gather info on installing a LS1 into an early Bronco (72). I want to do the L60E also. Advanced Adapters has an adapter to adapt the trans to the Dana 20 transfer case. Length of the LS1 engine/trans/adapter combo is 2” longer then the 302/c4 I have in there now. With out the mechanical fan, I think I can get the engine forward the 2” as to keep the transfer case drive train in the same place. Has any one seen or heard of someone doing this please let me know. Thanks for the info.
P.S. Please don't give me the Ford GM speach. I got it from a Bronco list. <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
Brad
Old 03-11-2003, 01:18 PM
jmd
jmd's Avatar
Default Re: LS1 Into Early Bronco Info
Is the 4WD GM 4L60-E out of the question? Obviously it would require driveshaft length changes. As far as moving the engine fwd. a bit; shouldn't be an issue as long as the oil pan and crossmember aren't too happy.
Old 03-12-2003, 09:38 AM
Jmd, what is a 4WD L60E? What is the difference from that and a L60E?
Old 03-12-2003, 09:49 AM
LS1 PWRD's Avatar
The 4L60E for the 4WD or AWD has a shorter output shaft then the 4L60E out of a regular RWD vehicle.
Quick Reply: LS1 Into Early Bronco Info
