cowl induction w/backwards LS manifold
has anyone considered mounting a LS manifold backwards and getting cold air from the cowl, kind of like the original cowl induction on the 67-68 z/28 that had a flat hood? does anyone see any problems/issues with this?
One thing... might not really be a problem, but I think it will be a little nosier inside the engine compartment.
ive always wanted to try the same thing. In the old school street rods they have the vent in the middle of the cowl, I want to run a ram air setup into one of those off a reverse mounted ls1 intake.
yea, lots of intake noise, as well as somethin weird with the throttle cable and vaccum for the brake booster if you would be using it. and i think the tb would becompletely interfering with your firewall not to mention maf and ducting.
However i dont see any reason why it could not be done witha front facing tb, maybe a little more tubing but muuuch less work in the end, something ive been considering for mine. If i end up havin time to do it ill post pics, just not sure if ill like having somethin covering up my engine....
i was going to do that, but i'd have to use a hydraboost or something for the vacuum, and figure out a way to smooth the back of the intake. Mine's really ugly, so i'm going to leave the intake as-is, i polished the TB to make it look pretty, and use the cowl hood open as a sort of pressure relief. I'm sure the air moving over the top of the hood will extract hot air from the engine compartment, especially at freeway speeds. If you do it, post pics =)
olly
olly
I thought of using my cowl vent for intake air but decided I didn't need that noise into the interior, the cowl vent in these old cars isn't ducted or anything and are just open inside under the dash. I'm ducting air from mine to my Hot Rod Air A/C system.
the MAP sensor wires need to be extended.
the brake booster line will now be much farther away. same with the HVAC lines.
the throttle cables have to be looped around to connect.
also, if you still have the vapor purge, you need to move the wires around on the intake harness. if you remove the vapor purge, you can use that vac source for the HVAC... i wouldnt try it for the the brake or the MAP though...
overall, its not that hard of a job to do, but it does present some problems depending on the car its done on.
