Painless harness (alternator wiring) question
the painless harness i just got does not seem to have a plug on it for the alternator. does anyone have any info on how i need to wire the thing up?
sawzall wielding director
painless didn`t include a plug? What year computer are you running? If it is a 98 you will have to add in a light or resistor. If it is a 99+ computer there should be a red wire in connector C2 (blue connector) pin #15 on the computer that goes to the weatherpack connector pin B on the alt.
it didn't come with a plug on it nor can i find a wire for it in the harness anywhere. i also don't have a spare plug to use but i'll make due just for now with some creative work with small spade connectors. i found a site that said that there were two wires that needed to be connected.
let me know if this is correct (from the site modified for easier understanding):
looking down on the alternator in the car, we'll call the 4 pins starting from driver's side A,B,C,D. A and C are unused. B gets wired to switched 12v with either a 50ohm resistor or a small light bulb in line. D gets wired to constant battery 12v per their instructions.
If the alternator is from an 02 f-body you only have one wire to worry about. The power for terminal D is already sourced internally in the alt so no external wiring is needed. Terminal B needs a switched ignition source either wired through an idiot light for the dash or a 470 Ohm 1/2 watt resistor. If you can get the search to work LS7Power has wiring diagrams, but I can`t seem to find the link right now. There is also info in this thread https://ls1tech.com/forums/showthrea...ght=alternator
you guys are life savers! thanks!
car started right up after i got the air out of the fuel system and is charging nicely. i ran two 220ohm resistors i had laying around in series so i think 440 Ohms should work ok.
