harness
Old 10-02-2008, 10:05 PM
blown0347's Avatar
Default harness
exactly what harness is needed to run an lsx motor in a foxbody?? just the computer and its harness?
Old 10-03-2008, 08:29 PM
13 Second Truck Club
726.0chevelle's Avatar
it depends what kind of tb you plan on using it will be alot cheaper to go with a cable driven tb rather than a drive by wire tb also you need to decide what tranny you will be using and what your budget is looking like around 300 for a factory one that has been cut to 800+ for a custom a drive by wire harness i heard was around 1300+
Old 10-04-2008, 03:23 PM
blown0347's Avatar
its going to be a cable on the tb not a drive by. and the trans will be a t 350. so will it just be the comp and its harness?
Old 10-04-2008, 04:15 PM
12thstreetjunkman's Avatar
yup pretty much any will work, f-body, vette, or truck. The truck will probably be the cheapest. You may need different plugs for the injectors but otherwise pretty much the same, just get the pcm that matches the harness, and program it.
Old 10-04-2008, 07:22 PM
cacmanjr's Avatar
If you are going to use a TH350 you will have to figure out how to connect the kick down cable to the throttle body or gas pedal.
Old 10-04-2008, 10:29 PM
blown0347's Avatar
its gonna be a manual valve body.. does the 350 just bolt right up to the lsx block or are the dowel pins different?
Old 10-04-2008, 11:49 PM
cacmanjr's Avatar
You should be able to gt 5 bolts in. You will need the proper flex plate set up to bolt to the 350.
