LSX oil pans
#502
#505
ls3 oil pan
i dont see much info on a 2011 camaro oil pan.i have a 4 seater dune buggy with a 2001 5.3 truck motor.the truck oil pan fits great but just hangs down to low.the oil filter barely clears my wishbone running the length of the engine.i thought about going to a gto pan the front sump wouldnt be a problem it would probably be beneficial hill climbing.is the oil cooler removeable on the ls3?anyone have the dimensions?i was interested in the ls3 pan because it looks like i would gain some more oil filter clearance.i think if i run anything other than the truck or ls3 pan i will have to run a oil filter adapter,which one is recommended
#506
Be sure to check out our swap oil pans! They may be just what you're needing to complete your swap. Feel free to email (sales@sikky.com) or PM us on here for any questions you have.
http://www.sikky.com/view_item.php?id=165&catid=13
#507
Question ?
I had a CTS-V Oil pan on my Ls1/M3 swap, but swapped it for a stock Fbody one as the V was too low. Anyways the person I swapped pans with didn't have the windage and pickup tube, so I kept the V's to see if it would somehow work. Obviously the tray doesn't at all, but just wondering if there is a difference between the stock Fbody pickup tube "12558251" and the CTS-V one. I already have to order a new windage tray and figured might as well get a stock pickup tube as well.
But if there is no major difference I'll just use the V tube.
#508
#512
Lower bellhousing bolts? Moroso pan..
Hi - LS newb here...
My LSX is going into a '90 300zx. This swap is infamous for oil pan woes and pretty much guarantees a custom solution.
I don't tig alu, but I can hack mig steel I am probably going to start with the Moroso steel pan so I have something I can work with. I like to keep as much as possible 'in house', and I'm sure I will need to make more than a few adjustments. I will be adapting the stock 300zx 5spd me hopes.
I see that the moroso has no provisions for the lower bellhousing bolts. My question is -
If you are using the Moroso pan, are you comfortable with this?
I see that most aftermarket SBC bellhousing adapter plates have no provision for lower bolts so I'm thinking it's Ok but....
Oh, wanna trade my truck pan for a moroso?
#516
Read forums til I fell asleep
How about this...?
Does the CTS-v pan come with the bleed valve in the pan for DoD/AFM?
Can the F-body or any other pre-2005 be drilled and tapped for the bleed valve?
My wife wants to keep the DoD on her stock 5.3 and I need a pan 1.5 inches shorter than a truck pan.
#518
Fox body 6.0 Pan
I have searched this site for an answer but can't seem to find an answer.
Simple question, I am using a AJE K-member in a Foxbody Mustang. And I am swapping in a 6.0 stock block Truck motor. Will I need swap the oil pan or will the truck pan work?
This is not a DD. Only occaisonal street use. Lot's of strip time.
Surely someone has experience with this. Anyone?
#519
