Another Mustang LS2 swap in progress...
Old 01-15-2008, 10:44 PM
jw33's Avatar
I will probably need to get some spacers machined to offset the sway bar forward and down. Hopefully that will work. The motor goes in with the trans. attached and when I get it almost set I hook up the motor mounts. No big deal, I'm pretty good at it now...
Got the foot pedals and made a mount for the clutch master cylinder tonight. The pedals are from a '88 turbo coupe. Here are a few pictures of it out of the car. I still need to finish welding a few joints and rattle can the bare metal.
Old 01-16-2008, 08:44 PM
nova69's Avatar
looks great keep post pics
Old 01-17-2008, 01:32 AM
WILWAXU's Avatar
VERY nice work. Should be a cool car!
Old 01-17-2008, 07:56 AM
97'-lt1's Avatar
Very nice..I can't wait to get started on mine, or well actually working on it instead of gathering parts..
Old 02-07-2008, 10:12 PM
jw33's Avatar
Got a few more things done in the last few weeks. Got the motor and tranny in the car for the last time, got the pedals and clutch master mounted, ran -3 braided hose for the pressure and the remote bleeder, installed the alluminum flywheel and LS7 clutch, got the harness mostly in, and got the headers made up.
I used my ol MAC 351 swap headers and it wasn't too bad. On the passenger side all I had to do was chop off the flanges and weld on the LS1 style flange. On the driver side I had to move the two front tubes around a little and make the rear tubes a little longer. Not too hard and while I was at it I took off the ball-socket joint and put a V-band style flange. Here are some pics of the headers off the car and I'l get some with them installed later on.
Drivers side
Passenger side
I'm going to leave them uncoated until I can get the car running. I would hate to get them coated and then for them to leak somewhere where I welded or rub somewhere....
Old 02-07-2008, 11:33 PM
JoeSS's Avatar
I use Gto headers for mine and had to modify the driver side. I just need to run the harness and buy fittings for the fuel system.
Old 02-08-2008, 12:18 AM
Sunset'01Z's Avatar
love it. built ford tough with chevy stuff
Old 02-17-2008, 07:57 PM
adam`'s Avatar
any more updated? i want to see how you get your tranny dipstick tube in that firewall clearance is so small there is no way you can use the one that bolts to the back of the head. i just ordered a lokar one. also, what did you decide on for the driveshaft?
Old 02-17-2008, 08:28 PM
jw33's Avatar
It's an M6 car, but yeah getting to that top bolt is very tight. I dropped the motor in with the tranny attached though. I want this car to be as light in the front end as possible. No real big updates for now. I got the headers, intake, injectors, TB, wiring harness, starter, and PS pump, all on the car. I need to order some AN fittings for the fuel system and the new gauges. I might do some small stuff this week if I get a minute or two of free time. Although my 5 day old daughter may have something to say about it...
Old 02-17-2008, 11:15 PM
Rameaux's Avatar
Default Stang
I am not much of a Stang guy at all, but it is what is on the inside that counts.
Old 02-18-2008, 11:06 AM
Stampede4ever's Avatar
How much did the wiring cost you?
Thanks.
Old 02-18-2008, 03:39 PM
  #32
jw33's Avatar
I paid 815 for the wiring harness, ecm, O2 sensors, MAF/IAT, and the DBW pedal.
Old 03-01-2008, 06:00 PM
  #33
99Saleen's Avatar
I have a 99 GT convertible that next winter i will be doing a LS1/t56 swap, what K-member and other parts will i need to get the motor/trans bolted up into the car and running? thanks
Old 03-01-2008, 07:11 PM
  #34
jw33's Avatar
Any number of aftermarket K-members will work. Do some research if you plan on driving the car on the street much. A lot of guys get away with the light weight drag k-members, but they are really thin and can break. If you plan on going around corners there are really only two choices, Griggs and Maximum Motorsports. Everything is a copy of those two or they are for drag racing.
Old 03-02-2008, 10:14 PM
  #35
jw33's Avatar
Got the gauges wired up and partially installed in the dash. I still need to route a "few" wires behind the dash, but I ran out of time today. I'm super crazy when it comes to making sure the wires are clean/neat. I used the MC machine dash plate and it turned out awsome. I had to trim a few places in the dash, but these look really good compared to some other I have seen in my opinion. No pictures of them fully installed yet...
Headers are on the car and I have the harness mostly plugged in. I just need to straighten up where everything is going to lay and install a few more small things. Won't be much longer...
Old 03-05-2008, 07:57 AM
  #36
SOM68SS's Avatar
What were the clearance issues you had that required the drivers side Header modifications. Was it the steering shaft?
Old 03-05-2008, 05:17 PM
  #37
jw33's Avatar
Yeah, the steering shaft was hitting one of the tubes if I remember right. No big deal....
Old 03-06-2008, 11:11 AM
  #38
BLK02SS's Avatar
what oil pan did you use and what harness did you use? did you have to change the reluctor wheel on the crank? was your engine a 24 or 54 tooth reluctor?
thanks chuck
Old 03-06-2008, 11:17 AM
  #39
BigBronco's Avatar
Awesome!
Old 03-06-2008, 04:44 PM
  #40
jw33's Avatar
thanks chuck
F-body oil pan and I used the new GM harness. The motor is a '07 LS2 with the 58 tooth reluctor wheel. Here's a link to another thread about the harness. Some people like to **** all over it because of whatever, but it is the best deal out there for a total package. My other option was more than twice what I spent on the GM harness and the GM harness came with a few sensors.....
https://ls1tech.com/forums/conversions-swaps/845442-another-harness-option.html
Quick Reply: Another Mustang LS2 swap in progress...
